Race Fuel!! Safe or not? - 600RR.net
post #1 of 16 (permalink) Old 06-14-2006, 12:44 PM Thread Starter
Exclamation Race Fuel!! Safe or not?
I was wondering if anyone knew if it was safe to run race fuel in a 04 cbr 600rr with yoshimura exhaust system and power commander III to drag. "not everday riding." i think i can get 107 or 108 octane at my local airport. I can also purchase 103 octane at my local drag strip.
SicCbr600RR is offline
post #2 of 16 (permalink) Old 06-14-2006, 12:52 PM
jshortsl's Avatar
jshortsl is offline
post #3 of 16 (permalink) Old 06-14-2006, 01:08 PM
Images: 3
It's just oxygenated...it's safe.
SilverSurfer is offline
post #4 of 16 (permalink) Old 06-14-2006, 01:12 PM
AlpineJim's Avatar
You might want to go get a custom map with race fuel...
Matthew
03' 600rr - Track
AlpineJim is offline
post #5 of 16 (permalink) Old 06-14-2006, 01:15 PM
lowlife's Avatar
don't bother with the high octane, look for an oxygenated fuel, try MR10 from VP, supposed to be good for 10% power increase over pump gas....
lowlife is offline
post #6 of 16 (permalink) Old 06-14-2006, 02:47 PM Thread Starter
you were saying get fuel from vp. what is "VP"?
post #7 of 16 (permalink) Old 06-14-2006, 02:52 PM
AlpineJim's Avatar
post #8 of 16 (permalink) Old 06-18-2006, 06:29 AM
Don't run aviation fuel you might see a loss on these type of engines.
Race Developments, UK. Race engines and dynojet centre.
Tim Radley is offline
post #9 of 16 (permalink) Old 06-18-2006, 08:58 AM
Your gonna rob horsepower from the engine with higher octane. Stick with 87. Higher octane burns slower causing expanding gases to go out the exhaust valve when it opens. unless you do engine mods you are wasting your money. Make sure you stay away from aviation fuel it contains lead and the lead wil eventually clog the injectors. It will also leave heavy deposits on the plugs.
Wingmaker is offline
post #10 of 16 (permalink) Old 06-18-2006, 09:59 PM
Unless you are going to run either VP MR9 or VP U4, or something similar by a different manufacture dont waste your money. Also, if you are not use to drag racing or havent even been yet dont get race fuel until after you have some good base line numbers to go with then put race fuel in and go back and compare your times to see if you are gaining anytime. Also, FYI, alot of race fuels have to be drained after use or ran completely out of the system if not you can damage your fuel system by letting it sit in there.
KawiHonda is offline
post #11 of 16 (permalink) Old 06-19-2006, 08:42 PM
I would hope its safe.... I love the smell of U4 in the morning!!!
and gotta agree with everyone... only worth it if you tune the engine with it on a dyno, and build a custom map.
RRLucky is offline
post #12 of 16 (permalink) Old 06-19-2006, 09:02 PM
People always think that higher octane means more power. Normally it means less. High octane just means you can compress the gas more before it combusts. Low octane will combust with more energy at lower compression.
jener8tionx is offline
post #13 of 16 (permalink) Old 06-19-2006, 09:26 PM
KulSecHskY's Avatar
Really? Never heard that before.
So if I dyno my RR with 87 octane as recoomended and lets say I get X amount of torque and hp, then I switch to 93 octane and use the same dyno, same conditions yada yada yada then I will in fact see a loss in power?
And assuming Honda left a little safety margin when recommending 87 octance, if I fill it up with 85 octance will I see a gain in power? Ofcourse assuming this will not cause detonation?
-Rich
KulSecHskY is offline
post #14 of 16 (permalink) Old 06-19-2006, 11:20 PM
gee
Overpaid South Pacific Barista overactive ADHD crew off their meds!!
gee's Avatar
nope if you use lower octane in you cbr engine the compression ratio is around 12:1 wot hes saying is that at 9:1 or there about you would see no power gain in using a higher octane fuel...
gee is offline
post #15 of 16 (permalink) Old 06-20-2006, 02:31 AM
What you will find is the higher octane pump fuels aren't just more octane, they are better ingredients which is why some brands make much more power than other of the same octane. This is why 93 makes more power than 87, its not to do with the octane rating.
post #16 of 16 (permalink) Old 06-20-2006, 09:07 AM
wow you learn something new every day, 87ron regular ei
here in oz 93 is about standard, and up to 98 for premium, but yeah im told allways run it on what's it tuned for,
btw i've head japan regular petrol is 100 RON, and premium is 110 RON
so i'd say high octaine fuel in a jap made bike should be ok with the right mapping,
buffaloo is offline
