telling the difference between titanium and stainless? - 600RR.net
post #1 of 15 (permalink) Old 12-13-2015, 04:14 PM Thread Starter
Picked up a used 2009 slip on akrapovic for my 2007.Knowing that the midpipe is different,and I may have some problems I was wanting to know how I can tell which material the midpipe is made of?(owner had no idea) in case I have to have a bracket welded onto it suit it matching up with the2007 frame mount.
lotus7 is offline
post #2 of 15 (permalink) Old 12-13-2015, 04:32 PM
Lifetime Premium
HartwickCBR's Avatar
You should be able to mount that up just fine without adding a new bracket. Many people have done it without issues, myself included. I currently have an 09-12 slip-on on my 08.
Odds are that midpipe is stainless thought if you really want to change the bracket.
HartwickCBR's 08 Pearl Orange Build: Link
HartwickCBR is offline
The Following User Says Thank You to HartwickCBR For This Useful Post:
lotus7 (12-13-2015)
post #3 of 15 (permalink) Old 12-13-2015, 04:38 PM
cbrkat28's Avatar
It's very probably stainless...tintanium is super expensive, and also usually blues
1971 Volkswagen 1302 (02.19.2015 - )
For Sale:
https://www.600rr.net/vb/153-07-13-rr...0rr-c-abs.html
cbrkat28 is offline
post #4 of 15 (permalink) Old 12-13-2015, 05:15 PM Thread Starter
hey thanks,
how far off was the mounting tab from matching up?
lotus7 is offline
post #5 of 15 (permalink) Old 12-13-2015, 05:55 PM
TheFozz08's Avatar
A good welder will be able to tell easily. But it's probably stainless as other people have said.
TheFozz08 is offline
post #6 of 15 (permalink) Old 12-13-2015, 06:25 PM
03cbr-rider's Avatar
The discoloration of titanium is much more intense as it heats up with exhaust systems. Stainless pipes tend to stay looking bronze colored, while titanium will turn blue, gold, purple, pink and you might even spot tiny blotches of green around welds. Not all stainless steel is nonmagnetic, titanium is though. If you can get a magnet to even slightly attract, you'll know right away it isn't titanium. You can try around the welds too, where the alloys break up more. You can also heat it up with a torch, compare the color patterns you get with stainless tubing and titanium, the actual crystallized surface of the titanium has a much larger oxide spectrum of colors other than bronze blue and purple.
03cbr-rider is offline
post #7 of 15 (permalink) Old 12-13-2015, 06:57 PM
tripage's Avatar
Feedback Score: 91 reviews
Good info above. Also titanium would be much lighter than stainless steel.. Surprisingly lighter than it appears.
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #8 of 15 (permalink) Old 12-13-2015, 11:31 PM
double0fox's Avatar
Hit one of the ends that you will not see mounted with a grinder. Sparks will be white(ish) if it is titanium. Any 13-8, 15-5 or 17-7 stainless will give off orange/redish sparks.
When in doubt. Flat out.
Iannone and Lorenzo are now seagulls buddies for life. -AF4iK
double0fox is offline
post #9 of 15 (permalink) Old 12-14-2015, 02:37 AM
cbrkat28's Avatar
Has anyone suggested using a magnet?
For Sale:
cbrkat28 is offline
post #10 of 15 (permalink) Old 12-14-2015, 04:47 AM
Soponcio Virtual's Avatar
Could be usefull...
A magnet would attract chromed parts but not Stainless steel...
IDK how would it react to Titanium...
Honda CBR600RR 2003 - Gone! (the blond)
Honda CBR600RR 2007 - On the road! (the brunette)
Soponcio Virtual is offline
post #11 of 15 (permalink) Old 12-14-2015, 09:27 AM Thread Starter
Tried the magnet on the midpipe and it does have a minimal attraction (not as much as a piece of steel) Then tried the magnet on the muffler which I know is titanium and zero attraction at all.Might as well been a piece of wood! So my question is answered in that the midpipe in stainless steel.I`m glad about that as should I need (or want) to have a mounting tab welded on the 2009 midpipe to make it fit my 2007 frame I am guessing that a welder will have an easier job tig welding stainless as opposed to titanium.Thanks for all the help guys.Looking forward to spring to get this pipe on!
lotus7 is offline
post #12 of 15 (permalink) Old 12-14-2015, 09:46 AM
cbrkat28's Avatar
Originally Posted by Soponcio Virtual View Post
Could be usefull...
Chromed plated steel isn't stainless steel; stainless steel is steel with a chromium content over 10% or something like that...It'll attract a magnet, but lightly since there isn't a lot of iron to do the attracting.
Titanium doesn't stick at all.
For Sale:
cbrkat28 is offline
post #13 of 15 (permalink) Old 12-14-2015, 11:20 AM
I know... Chromed can be any cheap metal, that is why they hook good to the magnet.
post #14 of 15 (permalink) Old 12-14-2015, 11:54 AM
cbrkat28's Avatar
Bingo; iron is cheap, and not in demand like aluminum which can be polished anyway...iron is what's magnetic.
For Sale:
cbrkat28 is offline
post #15 of 15 (permalink) Old 12-14-2015, 11:57 AM
Years and years of selling truck wheelcovers (lorry hubcaps for the brits!)... Both chromed or Stainless... I've learnt my lesson!
