Akrapovic - tips needed to sort a problem - 600RR.net
post #1 of 7 (permalink) Old 05-03-2016, 01:11 PM Thread Starter
JBizzzay's Avatar
Question Akrapovic - tips needed to sort a problem
Slightly random one, hoping someone can drop an inspired response in here.
Recently I was refitting the noise baffle on my Akra slip on. You may be familiar with the fact there's a small hole to the underside of the muffler through which a small screw with a crush washer secures the baffle/db killer once inserted into the exhaust.
Annoyingly I have done this loads of times with no problem, however last time out the bolt dropped off my Allen key and fell into the muffler surround. This is a sealed unit and I'm certain it hasn't dropped down into the exhaust itself, but what I can't fathom is how to get it out, since the muffler is a sealed, riveted unit.
Hopefully I have explained myself clearly enough, if anyone can think of a solution or you've done the same please advise. Can post pics if necessary.
JBizzzay is offline
post #2 of 7 (permalink) Old 05-03-2016, 01:20 PM Thread Starter
JBizzzay's Avatar
I figured pictures would be a lot more easy to explain the problem.
This is the hole the screw fell into.
This is how the silencer is sealed.
JBizzzay is offline
post #3 of 7 (permalink) Old 05-03-2016, 01:21 PM
hero danny's Avatar
Maybe can you just take the exhaust off and tip it upside down and hopefully the bolt will fall out.
CHECK OUT MY YOUTUBE CHANNEL!
Mod List
-Akrapovic Slip on
-Arrow Headers
-DynoJet PCV
-DynoJet Quick Shifter
-K&N Air Filter
-Servo Delete
-PAIR Block off
hero danny is offline
post #4 of 7 (permalink) Old 05-03-2016, 01:27 PM Thread Starter
JBizzzay's Avatar
This is why I posted, sometimes the glaringly obvious doesn't spring to mind! Thanks, will give that a go. It's quite a small space so I reckon it's wedged in but worth a pop.
JBizzzay is offline
post #5 of 7 (permalink) Old 05-03-2016, 01:47 PM
hero danny's Avatar
Be sure to hit the sides with your palm to help "dislodge" it if it's stuck. If that doesn't work then there is always a flexible magnetic pick up tool.
Mod List
-Akrapovic Slip on
-Arrow Headers
-DynoJet PCV
-K&N Air Filter
-Servo Delete
-PAIR Block off
post #6 of 7 (permalink) Old 05-03-2016, 11:06 PM
BOTM Winner 07/16
rinonz's Avatar
I did that... Took some pretty extreme shaking and tipping to get the bolt out :P
rinonz is offline
post #7 of 7 (permalink) Old 05-05-2016, 05:32 AM Thread Starter
JBizzzay's Avatar
So with some banging and manipulation of the carbon fibre exhaust surround, I managed to locate and remove the crush washer. Still no sign of the bolt so that may be at the track or on the road somewhere! Will persevere a little longer.
JBizzzay is offline
