What is the best air/fuel ratio? - 600RR.net
post #1 of 7 (permalink) Old 01-27-2017, 01:48 PM Thread Starter
I have a 600rr-c with a Power commander V and autotune kit. Now i was hoping to set the air/fuel ratio for max torque/power throughout the rev range. Can someone point me in the right direction of wjat i will need to do to find this out please.
Many thanks
Dindanio is offline
post #2 of 7 (permalink) Old 01-27-2017, 09:25 PM
go to Dynojet website and start reading.
tary preisser is offline
post #3 of 7 (permalink) Old 01-27-2017, 09:29 PM
if it were that simple tuning wouldn't even be a business.
tuners don't just set a target AFR and put that across the board. of course you want "max torque/power throughout the rev range", so does everyone on the planet. who would want less?
if you think that there is a number that you can put in a box that will deliver this, you are in for a disappointment.
if you want your bike running absolutely optimally, you want to go to the best tuner you can find and bring money.
if you want your bike to run nicely, at a good safe AFR, go do some reading.
you won't get a magic number to solve all your problems.
wibbly is offline
post #4 of 7 (permalink) Old 01-28-2017, 01:26 AM Thread Starter
Yeah im currently reading but was asking on here hoping i can get some helpful tips.i was planning on investing in a custom map but I did ask a tuner yesterday who basically said its either one or the other. Its pointless having autotune and getting a custom map as the autotune will try to recorrect what has been done.
As far as dynojet i called but none of the technical support guys were around.
So i do try and do my research just tryingto explore all options with advice.
Dindanio is offline
post #5 of 7 (permalink) Old 01-28-2017, 09:27 AM
OveRReV's Avatar
Images: 16
Depends on the fuel but if you have 100% gasoline (no ethanol) in your tank then your target numbers will be 13.2 max power lean to 12.5 max power rich.
For gasoline with 10% ethanol content (E10) your target numbers will be a bit richer, 12.7 max power lean to 12.0 max power rich.
Most tuners i know run 13.2 with 100% gas & 12.7 with E10, i also tune my PCV but don't rely on the autotune function of the autotune module, most of the time they'll skip some cells that need the most tuning, for example i've struggled autotuning the 11,000 to 13,000 rpm range at 100% throttle on my HRC ECU which runs at 11.0 AFR on my POD300 datalogger, no matter how long & frequently i ran through those rev range the autotune couldn't give an adjustment so i stopped just turned off the autotune function & used the autotune module as a purely data collection module & manually adjusted all the cells. After a few runs i was able to lean out & develop a more linear AFR line on my fuel mapping.
HRC AMA ECU stock fuel mapping
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #6 of 7 (permalink) Old 01-28-2017, 09:33 AM
OveRReV's Avatar
Images: 16
My AFR at 100% after a few tuning runs & adjustments.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #7 of 7 (permalink) Old 01-29-2017, 03:04 AM Thread Starter
Thats brillant it gives me something to work on. Thanks alot man.
Dindanio is offline
