Question on a 04 cbr600rr issue above 12k - 600RR.net
post #1 of 10 (permalink) Old 04-18-2017, 12:04 PM Thread Starter
Ok so here's what happens... The bike cruises just fine but it really struggles to go above 12k... If it's NOT under load in nuetral it's just fine, but in first it'll kinda go, in 2nd and 3rd it's a chore.... Reading up on other forums, I'm believing that it's the fuel pump... So I'm wanting to buy the 60 dollar fuel pump with a screen and just "rebuild" my factory fuel pump assembly. Just need advice on this issue... Because I've also read one other forum that said he replaced his fuel pump and it didn't fix anything... I do have 30k miles on my bike, with NO previous maintenance records
xhonda1991x is offline
post #2 of 10 (permalink) Old 04-18-2017, 12:34 PM
NewRedRider's Avatar
Images: 24
Did you check to make sure your fuel line is in the cut away notch under the tank? Sometimes the fuel line can become kinked or pinched which reduces the pressure.
You can also get a less expensive motor for a rebuild here. But I've never used them.
http://www.ebay.com/itm/111876828786
I'm in the same position right now except my fuel pump completely went out. I'm going to start a thread asking for anyone with experience on these rebuild motors.
Sent from my XT1097 using Tapatalk
NewRedRider is offline
The Following User Says Thank You to NewRedRider For This Useful Post:
xhonda1991x (04-18-2017)
post #3 of 10 (permalink) Old 04-18-2017, 01:13 PM Thread Starter
NEW Replacement Fuel Pump Kit w Filter Honda CBR600RR CBR600F4 CBR 600 F4 RR | eBay
i have not checked that no... a shop put that all back together a couple weeks ago, i would like to imagine that they did that properly but who knows i suppose. like i said its fine until 12k and then its just like a slug... it fights me to climb any higher!
post #4 of 10 (permalink) Old 04-18-2017, 01:27 PM
Images: 24
That's a very common mistake. If they were just servicing the bike, take it back and tell them what's going on. Hopefully they're not trying to pull a fast one by purposely pinching the hose to sell you a $500 fuel pump. It would not hurt to run some Sea-foam through it either.
post #5 of 10 (permalink) Old 04-18-2017, 01:33 PM Thread Starter
i currently already have sea foam in it... it hasnt seemed to fix the problem.... so tell me what to look for, im going to take out the fuel pump this weekend just need to know when i lift the tank where to look and how to know if it was kinked?
post #6 of 10 (permalink) Old 04-18-2017, 01:37 PM
Images: 24
There's a clamp under the tank that holds the fuel line in place and a noticeable groove where the fuel line is designed to go.
Check theses threads for more instructions on the fuel pump removal....
https://www.600rr.net/vb/showthread.php?t=558298
https://www.600rr.net/vb/showthread.php?t=559962
post #7 of 10 (permalink) Old 04-18-2017, 01:53 PM Thread Starter
Not starting after fuel pump replacement - 600RR.net
Write up please (fuel pump removal and install) - 600RR.net
i really hope thats the problem, but if not i guess a 60 dollar fuel pump she comes.... hopefully thats it!
post #8 of 10 (permalink) Old 04-18-2017, 02:02 PM Thread Starter
Plus once I take the tank up, wouldn't the line un kink and wouldve never known that it was kinked?
post #9 of 10 (permalink) Old 04-18-2017, 02:43 PM
Images: 24
You'll be able to see whether it's in the clamp and out of the groove once you start raising the tank. Just peek under before you raise it up too far.
post #10 of 10 (permalink) Old 04-18-2017, 02:45 PM Thread Starter
ok, ill probably end up doing that on Friday. (work tons of hours haha)
