06 CBR600RR Fuel Pump Issues - 600RR.net
post #1 of 2 (permalink) Old 01-09-2019, 08:06 PM Thread Starter
** Fixed **
I have noticed that my fuel pump is no longer running. Bike is around 35,000 miles. Things I have done:
Jumped the fuel pump directly to the battery. The fuel pump started right up. I did have to connect the ground and the yellow wire. Connecting the black and the red did not work. (Anybody know why there are 3 wires to this?)
Pulled the gas hose off of the fuel rod and verified gas is cycling through
Checked the relay, it has the same input as output.
Double, triple, quadruple checked that my kill switch is in the off position. The bike is in neutral.
The bike turns over so I sprayed starting fluid into the air box. I had a few kicks but nothing consistent. I'm wondering at this point if i even have good spark
** Update **
I switched the relay with the headlight relay and it started up. Headlight relay is up under the front fairings in front/in-between the two headlights.
Troy Jordan is offline
The Following User Says Thank You to Troy Jordan For This Useful Post:
Wazoo (01-10-2019)
post #2 of 2 (permalink) Old 01-10-2019, 06:34 PM
story028's Avatar
So bikes up and running smooth? i was having problems with my 06 bogging down (29,xxx miles). After some searching determined it was the TPS. Ended up replacing the entire throttle body since you "can't replace tps sensor".
When nothing goes right... go left
story028 is offline
