Aftermarket hearder? Cutting muffler? - 600RR.net
post #1 of 8 (permalink) Old 01-28-2007, 08:06 PM Thread Starter
Hey I was just wondering if anyone out there has shortened up a carbon fiber exhaust muffler. I have the two bros slip on and I don't like how it sticks out so far. Also is there a aftermarket header that you can purchase to mount up to this?
Eclipse2 is offline
post #2 of 8 (permalink) Old 01-28-2007, 09:58 PM
tripage's Avatar
Feedback Score: 91 reviews
I did my 2 bros titanium.. Cut out 2"...
Pretty easy, drill out the rivets on the cap, pull it off take out the baffle cut the can and the baffle reinstall and replace the rivets...
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #3 of 8 (permalink) Old 01-28-2007, 10:13 PM
from a cf faq
How do I cut it?
For the thinner pieces (.020 and smaller), you can actually just use a good pair of scissors. Thicker material you may be able to use a tin-snips, but the optimal method is to use a band saw or scroll saw. Fast-cutting, as with a jigsaw or circular saw tends to make a lot of dust, and can leave a less-smooth cut, so slow-cutting is typically better. When using a saw, it is a good idea to protect the glossy finish from scratches, with some masking or similar tape. Finish up the edges with a 100 grit sandpaper to take the rough spots off, then detail with 400 grit. If you're really fancy, you can use a Waterjet or Laser-cutting service. (Although laser-cutting carbon fiber tends to really stink as the material burns!)
usmcr6 is offline
post #4 of 8 (permalink) Old 01-28-2007, 11:31 PM Thread Starter
ok thanks guys. once you cut ur exhaust did you have a problem witht the exhaust melting the brake light? jw
Eclipse2 is offline
post #5 of 8 (permalink) Old 01-29-2007, 12:12 AM
Just remember your exhaust is going to be louder now, take that into consideration
takiRR is offline
post #6 of 8 (permalink) Old 01-29-2007, 12:22 AM Thread Starter
well I definately don't mind that!
Eclipse2 is offline
post #7 of 8 (permalink) Old 01-29-2007, 06:41 AM
tripage's Avatar
No melting... just need to clean the light every now and then because of the carbon deposits exiting.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #8 of 8 (permalink) Old 01-29-2007, 01:50 PM Thread Starter
sweet! Anyone know of an aftermarket header that will you can buy and will fit that?
Eclipse2 is offline
