power commander 2nd hand! - 600RR.net
post #1 of 35 (permalink) Old 02-22-2007, 04:11 PM Thread Starter
Exclamation power commander 2nd hand!
I recieved my pc III today, 2nd hand off ebay and it didn't have the software with it, is it the same as i can download off the power commander website?
....and im in the middle of installing it now, and have gotten as far as disconnecting the stock connecters, all came easy of except for the first one, been trying ages! head is goin! ready to smash things up....any sugggestuions on how to get off ??
teamstinkin is offline
post #2 of 35 (permalink) Old 02-22-2007, 06:00 PM
AlpineJim's Avatar
Are you talking about the TPS connector? I used a small but long screwdrive to release it and did the same to seat the PCIII connector..
If its one of the FI just walk away for a few and try again should come off like the other...
Matthew
03' 600rr - Track
AlpineJim is offline
post #3 of 35 (permalink) Old 02-23-2007, 07:48 AM
AFwestPunk's Avatar
why didn't i think of that... second hand purchase
OG PostwhoreScooter riding HK chasin' SOB
AFwestPunk is offline
post #4 of 35 (permalink) Old 02-23-2007, 08:26 AM Thread Starter
tps connectors?
im a complete novice when it comes to mechanics, its an 03, if that makes a difference?
ive tried the screwdriver etc, just will take patients i fink.
post #5 of 35 (permalink) Old 02-23-2007, 11:35 AM
Post Whore Extraordinaire
snikwad's Avatar
Images: 15
Feedback Score: 16 reviews
teamstinkin... go to powercommander.com and find the instalation instructions. print it and go from there.
Its really clear and has pics...
You should have 5 connectors, the one that look a little different form the the rest is the TPS connector (throttle position sensor)
After connecting, zero, or reset the Throttle position to match what your bike's idle position is... Also very easy and instructions on the site, all pdf format.
From there, just make sure you download European model specific software.
I guess there is a slight difference, who knows.
Asl Paul if he'll let you try his map...
If you have any problems you can PM me or post it on here.
No more mod listing, shits is STILL too long
03 600RR > 04 1000RR > 06 R6V > 05 600RR > 06 R1 > 09 1000RR > 10 RSV4R :gun:
snikwad is offline
post #6 of 35 (permalink) Old 02-23-2007, 11:35 AM
snikwad's Avatar
Images: 15
Oh, if you didnt take off the left side plastic, you'll be at it even longer...
snikwad is offline
post #7 of 35 (permalink) Old 02-23-2007, 06:07 PM Thread Starter
my bike is stripped for paint so its all off.
yeh im following the power commander instructions and i know how to do it, the tps connector is the one you put the wire tap on to i assume, i don't know what they are called but know where everythying is going. just this connector the first one of the four! headwork, ive sprayed ac-90 (wd40) oil on it now so hopefully that wil free it. thanks everyone!
post #8 of 35 (permalink) Old 02-23-2007, 07:08 PM
snikwad's Avatar
Images: 15
wire tap? dude its a plastic plug similar to the ones for the injectors.
the only wire i can think of is the ground that goes to the battery terminal.
Are you looking at the right instructions.
snikwad is offline
post #9 of 35 (permalink) Old 02-23-2007, 10:47 PM
99SH's Avatar
^^ The older PC3's you had to tap into the TPS, it didnt come with a harness...
99SH is offline
post #10 of 35 (permalink) Old 02-23-2007, 10:49 PM
snikwad's Avatar
Images: 15
oh, ok, sorry, had no idea about that one.
snikwad is offline
post #11 of 35 (permalink) Old 02-24-2007, 11:04 AM
07 TRACK SLAG!
paul46rider's Avatar
Images: 55
not on a power commander for an 03-04, wiring wise its exactly the same as the 05-06
paul46rider is offline
post #12 of 35 (permalink) Old 02-24-2007, 11:22 AM
99SH's Avatar
The wiring is the same, but the pre days of the PCIII for the 03-04's they supplied a scotchlock tap. Around late summer of 04' they switched to a harness connector for the TPS. If you don't believe me you can search this forum for people installing their PC3's with the tap...
99SH is offline
post #13 of 35 (permalink) Old 02-24-2007, 11:38 AM
AlpineJim's Avatar
Heres the one for the connector...
http://powercommander.com/maps/install/I115-411b.pdf
Matthew
03' 600rr - Track
post #14 of 35 (permalink) Old 02-25-2007, 10:06 AM Thread Starter
right ive done it !!!
....but what i haven't done is remove the bracket to put the pc III harness under, so the seat goes back on flush. the reason i skipped this is because the nuts underneath are so hard to get to, and when i do get them off how, do you get them back on???? its so tight, that you can't place the nut underneath to put the bolt through?
any ideas cos one nut has already dropped down into the plastic mould, never to be seen again!
yeh mine had a 'wire tap', weren't too bad, my 1st throttle body connector was the one i couldn't get off! headwork, just wouldn't give!
post #15 of 35 (permalink) Old 02-25-2007, 02:41 PM
snikwad's Avatar
Images: 15
^ i didnt take that bracket off, i didnt have any tools, i ine by one pushed the connectors under it then pulled the wire.
snikwad is offline
post #16 of 35 (permalink) Old 02-25-2007, 02:47 PM Thread Starter
mines all connected up now.....aw fuk it! i'll have to start again! that bracket !!!!!!
in for paint 2mo!...been a long time coming!!
post #17 of 35 (permalink) Old 02-26-2007, 10:34 AM Thread Starter
rite! ive got it all on, its under the bracket, exactly the same as the instructions!
ive got the engine running....wot do i do next? cos ive revved it, and the green lights run up & down, ive pressed the low, med, high buttons, nothing is happening?
my bike is still with out fairings, so havnt taken it for a spin, is the power commander already doin sumfin?
remember i haven't got the original instructions (2nd hand) so a bit lost here. thanks
post #18 of 35 (permalink) Old 02-26-2007, 07:24 PM
snikwad's Avatar
Images: 15
^ the lights are normal..
if they ALL go out with the engine worry, then u have a problem.
You need to set the 0% throttle position, download the fuel accelerator and then find a map to your liking.
snikwad is offline
post #19 of 35 (permalink) Old 02-27-2007, 08:26 AM Thread Starter
ok, i'll give that a go. thanks
post #20 of 35 (permalink) Old 02-27-2007, 10:29 AM
NewRedRider's Avatar
Images: 24
see here....
http://www.powercommander.com/tut_download.shtml
Try some different maps that match your bikes configuration. (i.e. slip-on, air filter...etc) Disregard the name brand. Find one that works the best for you until you can have it mapped.
NewRedRider is offline
post #21 of 35 (permalink) Old 02-27-2007, 01:26 PM
snikwad's Avatar
Images: 15
wise words being spoken... ive tried several maps, right now im running a map for an Arata s/o an dit is bad ass, mad torque and pull, i tried a map for a sato s/o and that thing has less torque down low, pops less, but pulls like a freight train at the top end. both better than the BS map on the site, so try different ones, ask members to email you maps to try and find the one you lie the best untill you can get it mapped.
snikwad is offline
post #22 of 35 (permalink) Old 03-01-2007, 04:01 PM Thread Starter
panic stations !! ive had my plastics back from paint & have started to put my bike back 2gether.
only when i have gone to wire up my tail light, no power is goin to the rear, the connectors i mean.
so i pulls it off, tries my old light to make sure it isn't the new that is faulty, that doesn't work either, so defo, no power goin there.
whats worse is i turn my ignition on and my electronic display (clocks etc) isn't workin either.
im really paniking now, ive just fitted a power commander, may b its that?
shall i disconnect the battery to see if it will reset everything?
check fuses? where are they?
help please!!
post #23 of 35 (permalink) Old 03-01-2007, 04:04 PM
snikwad's Avatar
Images: 15
ok, you plugged in the taillight and turned the ignition on and nothing happen?
Any other lights out, turn signals?
maybe you had the power on at some point in the install and blew a fuse.
Fuses are on the left side under the plastic, kinda under the left intake tube.
snikwad is offline
post #24 of 35 (permalink) Old 03-01-2007, 04:28 PM Thread Starter
mayb, tha fuses are in the black casing? i'll check on my cd rom manual 4 sure.
does the bike shut down things in priority? like saving the headlights till last cos u would obviously need them in the dark or does it all go at the same time? im wondering if the battery is just low.
the head lights are on, tail light isn't niether will indicators front or rear go on with it, and it starts sometimes so i get the impression that the battery is kinda healthy.
fuse sounds about rite
post #25 of 35 (permalink) Old 03-01-2007, 07:05 PM
snikwad's Avatar
Images: 15
i dont know how it works, but certain things are wired together, i blew the display fuse once and if i remember right the headlights still worked, and i still heard the injectors, but the display was dead.
Yes its in a little box, about 8x4x5cm cant miss it, rubberlike cover is a biacth to get back on.
Let us know what happens.
snikwad is offline
post #26 of 35 (permalink) Old 03-02-2007, 11:22 AM
Images: 24
If nothing is powered up check the main 30amp fuse under the seat behind the battery. Do you have the Power Commander instructions?
post #27 of 35 (permalink) Old 03-02-2007, 11:49 AM Thread Starter
ok. its was a fuse, the 10amp. which i have replaced only to be blown again. i got one in and its ok, only problem is when im trying to wire up my rear integrated tailight and motrax flushmounts the feed isn't a blinkin fast or slow feed, its constant. tried with resistors and still wont work??
post #28 of 35 (permalink) Old 03-02-2007, 12:04 PM
Images: 24
Check your wiring again for the short. Ignore the blinker rate for now and find the short. You probably don't have enough resistors or a large enough resistor. The blink rate is so fast that it appears solid. How did you wire the resistors in?
post #29 of 35 (permalink) Old 03-02-2007, 12:12 PM Thread Starter
tail light 1st then, it plugs straight in for the brake light. then ive got a brown/ blue either side for the indicators. so ive looped the resistor from brown to blue and then tried the single wire off the tail light each side. u follow?
post #30 of 35 (permalink) Old 03-02-2007, 12:14 PM Thread Starter
the resistors in a 50 what ever it reads in for the front, they supplied only 20 for the tail light so it must be enough?
