exhaust problem - 600RR.net
post #1 of 23 (permalink) Old 03-07-2007, 09:04 PM Thread Starter
cmsun's Avatar
exhaust problem
hey i just installed the Hamaguchi system on my 05 but i cant get the bike to start up. The battery isnt dead and i have a quarter tank of gas still. Does anyone have any idea what the problem could be?
cmsun is offline
post #2 of 23 (permalink) Old 03-07-2007, 09:09 PM
NewRedRider's Avatar
Images: 24
When the last time you had the bike running? Check your battery voltage anyway. You should have atleast 13.0v on a good battery.
NewRedRider is offline
post #3 of 23 (permalink) Old 03-07-2007, 09:13 PM
MajorRR's Avatar
May sound dumb but check kill switch and be sure its not in gear. Also, if its turning over check idle adjustment.
MajorRR is offline
post #4 of 23 (permalink) Old 03-07-2007, 10:31 PM
Feedback Score: 17 reviews
Did you install a PC3? Are all the cables plugged in correctly? Did you pinch your fuel line? Does the bike go through the startup routine/countdown when you turn the key initially?
“Give, and it shall be given to you. For whatever measure you deal out to others, it will be dealt to you in return.”
CCS# 280...I get bored easily
2010 Sponsors - if they can help a slow guy like me, imagine what they can do for you!
Vortex Racing
Drive Systems USA
alexm is offline
post #5 of 23 (permalink) Old 03-07-2007, 10:36 PM
hehe..i kno thats happened to me before...
aych2h is offline
post #6 of 23 (permalink) Old 03-07-2007, 11:12 PM Thread Starter
cmsun's Avatar
i havent installed my pc3 and the bike has been sitting for a couple months so ill check the voltage on the battery. ya i checked the kill switch when i first tried. i have done that before lol
cmsun is offline
post #7 of 23 (permalink) Old 03-08-2007, 11:20 AM
HomerSaurus's Avatar
When you say it doesn't start, do you mean it wont run, or it wont even try to turn over?
"It seemed like a good idea at the time."
HomerSaurus is offline
post #8 of 23 (permalink) Old 03-08-2007, 02:22 PM Thread Starter
cmsun's Avatar
When i try to start it up it tries to turn over but it doesnt
cmsun is offline
post #9 of 23 (permalink) Old 03-08-2007, 02:34 PM
Knightslugger
Posts: n/a
do you hear your Fuel pump working when you turn the ignition on?
post #10 of 23 (permalink) Old 03-08-2007, 03:00 PM
Sounds like your tilt sensor is stuck, or your throttle is not reading in the closed position. My throttle would do that every so often and the bike would just ping the starter, but no fire.
SILVR05600RR is offline
post #11 of 23 (permalink) Old 03-08-2007, 04:10 PM Thread Starter
cmsun's Avatar
when i turn the ignition i dont hear anything. i am gonna just play around with it... thanks for all ur input
cmsun is offline
post #12 of 23 (permalink) Old 03-08-2007, 04:12 PM
If you dont hear the fuel pump priming you probly blew a fuse.
RedFireRR is offline
post #13 of 23 (permalink) Old 03-08-2007, 04:14 PM Thread Starter
cmsun's Avatar
okay ill check the fuses thanks a bunch
cmsun is offline
post #14 of 23 (permalink) Old 03-08-2007, 05:02 PM
Knightslugger
Posts: n/a
the fuse you'll be looking for is under the tank (i think).
post #15 of 23 (permalink) Old 03-10-2007, 06:30 AM Thread Starter
cmsun's Avatar
so i checked the fuses they are all fine
cmsun is offline
post #16 of 23 (permalink) Old 03-10-2007, 09:18 AM
LonelyRR's Avatar
Images: 241
Its your battery! Bike been sitting.
Have a buddy help you bump start it
LonelyRR is offline
post #17 of 23 (permalink) Old 03-11-2007, 12:44 AM Thread Starter
cmsun's Avatar
okay cool ill try that
cmsun is offline
post #18 of 23 (permalink) Old 03-14-2007, 12:42 AM
RRnelcheeze's Avatar
check your BAS.
"You motorboating son-of-a-bitch!"
http://www.myspace.com/thegovernor
http://www.teamosg.com
RRnelcheeze is offline
post #19 of 23 (permalink) Old 03-14-2007, 05:16 PM Thread Starter
cmsun's Avatar
what is a BAS?
cmsun is offline
post #20 of 23 (permalink) Old 03-15-2007, 01:14 PM
cbrocket600's Avatar
Images: 19
Bank Angle Sensor......did it start before you took it apart?
"A good friend will come bail you out of jail...a true friend will be sitting next to you saying wow that was fun!"
NESBA #918
05 600rr -Hamaguchi-Factory Pro-Pc3 Usb-Euro Racing-Vortex-Renthal-EK-Galfer-Brembo-Greggs-Progrip-Michelin-Comp Werks-Carbon Works-Ohlins-Penske-HRC......
cbrocket600 is offline
post #21 of 23 (permalink) Old 03-15-2007, 04:42 PM Thread Starter
cmsun's Avatar
ya the bike started fine before... how would i check the BAS
cmsun is offline
post #22 of 23 (permalink) Old 03-15-2007, 05:09 PM
Knightslugger
Posts: n/a
Try resetting it.
with the key in the on position, cycle the kill switch from on to off then back to on, back to off, and switch the key to off. turn it back to the on position and switch the kill switch to on. you should hear the Fuel pump prime.
if it primed when you switched the ignition on to begin with and heard the Fuel Pump prime, then it's not your BAS.
post #23 of 23 (permalink) Old 03-15-2007, 05:25 PM Thread Starter
cmsun's Avatar
okay cool thanks a bunch!! ;)
cmsun is offline
