Fuel Pump Pressure - 600RR.net
post #1 of 18 (permalink) Old 03-27-2007, 09:49 PM Thread Starter
Fuel Pump Pressure
does anyone know if you can up the fuel pressure on the stock pump? i have a 2006 turbo 600rr and i need some more fuel. i really dont want to get a new fuel pump. any help would be nice.
z2ack is offline
post #2 of 18 (permalink) Old 03-27-2007, 09:56 PM
NewRedRider's Avatar
Images: 24
A new pump won't help with a regulator set at 50psi. Do you have a PCIII or any other fuel management system? How do you know you need more fuel "pressure"? Are you running lean somewhere?
NewRedRider is offline
post #3 of 18 (permalink) Old 03-27-2007, 09:57 PM
Images: 63
@[email protected] I want to see some pichers of that setup...........
BiGxbOix510 is offline
post #4 of 18 (permalink) Old 03-28-2007, 04:05 PM Thread Starter
yes i have 1 powercommander on the primary injectors, i have another one comming for the secondary injectors this week. yes i am running lean at high rpm.
z2ack is offline
post #5 of 18 (permalink) Old 03-28-2007, 04:20 PM
Knightslugger
Posts: n/a
pressure ain't gonna help, you're going to go through injectors like mad if you do. just get larger injectors and you'll be fine with the stock pump.
post #6 of 18 (permalink) Old 03-28-2007, 09:47 PM Thread Starter
where can i find larger injectors. ive looked everywhere
z2ack is offline
post #7 of 18 (permalink) Old 03-29-2007, 12:39 AM
Knightslugger
Posts: n/a
Um... on a car? those are usually bigger... less accurate but it'll get the large amount of fuel your motorcycle requires nw that you got that phat turbo on there.
otherwise, look at some custom solutions. you've got a drag bike, spend some money, that's why you have one.
post #8 of 18 (permalink) Old 03-29-2007, 05:19 PM Thread Starter
which car would you recomend looking at
z2ack is offline
post #9 of 18 (permalink) Old 03-29-2007, 10:20 PM
Images: 24
Have you dyno'd the bike and tried to adjust the fuel map? Have you had significant head/motor work done? Otherwise you should be able to adjust the fuel map with the stock injectors.
post #10 of 18 (permalink) Old 03-29-2007, 10:26 PM Thread Starter
oh yea, we dyno tuned the bike but ran out of fuel at 4 psi. thats why i bought another powercommander for the top injectors.
z2ack is offline
post #11 of 18 (permalink) Old 03-29-2007, 11:43 PM
Images: 24
I've never heard of anyone using a larger fuel pump but that doesn't mean it hasn't happened. Are you sure you don't have a bad fuel pump, bad regulator, pinched fuel line, or clogged fuel filter? Are you having problems at any certian RPM range? (i.e. 10k rpm and up)
post #12 of 18 (permalink) Old 03-30-2007, 12:18 AM
ifallssmiley's Avatar
I haven't worked on bikes much, but i'm an auto mechanic and the same principles apply. All you need to find is higher flow rate injectors. I'd talk to a honda car dealership and see if the parts guy can get you some specs on an injector for like an accord or civic. Don't forget though that if you go that route to get the connectors with them too, then just splice them in. Good luck with install and post some pics when completed I bet it looks sweet.
ifallssmiley is offline
post #13 of 18 (permalink) Old 03-30-2007, 11:55 AM
Knightslugger
Posts: n/a
I donno... how about a ferrari? or how about a RX8? Anything with bigger injectors that can pulse quickly will do...
post #14 of 18 (permalink) Old 03-30-2007, 01:45 PM
wtf makes this bike a turbo?
2005 Silver 600RR
-GPR
-R&R FE
-SPR LED light bar
Shooter3k is offline
post #15 of 18 (permalink) Old 03-30-2007, 01:59 PM
Knightslugger
Posts: n/a
two or three companies... it's not much.
post #16 of 18 (permalink) Old 03-30-2007, 04:07 PM
slab42's Avatar
Images: 13
When you put a turbo on a bike/car, it becomes a 'turbo' version. Really simple deduction...
to stay on topic tho...
If you are looking for larger injectors, check out injectors out of other turbo cars, like subarus, etc. Just an idea.
06 Silver 600RR
My mod thread
slab42 is offline
post #17 of 18 (permalink) Old 04-03-2007, 09:50 PM Thread Starter
well guys i dont need anymore fuel. we got about 150 hp out of the bike and had fuel to spare. we didnt want to take the boost above 7psi. so thanks for all the info.
z2ack is offline
post #18 of 18 (permalink) Old 04-13-2007, 08:58 AM
Who makes a turbo for the 600rr?
2005 Silver 600RR
-GPR
-R&R FE
-SPR LED light bar
