Aviation fuel questions - 600RR.net
post #1 of 53 (permalink) Old 04-02-2007, 12:43 PM Thread Starter
I have an 05 600rr I went to BP at a local airport and bought 5 gallons of aviation grade 101 fuel, my question is will this harm anything on the bike, eg
valve seats, cat's, oxygen sensors, im almost 95% sure it wont but i just want some more opinions.
Robebob is offline
post #2 of 53 (permalink) Old 04-02-2007, 01:15 PM
Monkey works will work for you :)
RowskisRR's Avatar
Images: 68
Feedback Score: 18 reviews
You probably bought 100LL, it should be blue in color. I would stay away from it, to much lead. If you want to run higher octane find a place that sells http://www.rockettbrand.com/ you can get 100 octane that is unleaded.
05 600RR-Track
06 1000RR-Street
98 CR250
04 CRF80-Wifes Pit Bike
www.monkeyworkscycles.com
Phone Orders 1-888-62CYCLE (29253)
Customer Service 1-386-322-3530
[email protected]
RowskisRR is offline
post #3 of 53 (permalink) Old 04-02-2007, 01:26 PM
jordanf600's Avatar
did you feel like you were flying?!?!?
the only difference between suicide and killing yourself is whether or not you had fun while doing it. ( Me )
I can picture in my mind a world without war, a world without hate.
And I can picture us attacking that world, because they'd never expect it. ( Jack Handey )
jordanf600 is offline
post #4 of 53 (permalink) Old 04-02-2007, 02:00 PM
Hailwood's Avatar
Leaded fuel is not good for catalytic converters.
I'm not sure one tank would cause a problem, but I probably wouldn't do it a second time.
Hailwood is offline
post #5 of 53 (permalink) Old 04-02-2007, 02:17 PM
so if you have a straight pipe with no cat, its ok to use leaded fuel?
usmcr6 is offline
post #6 of 53 (permalink) Old 04-02-2007, 02:25 PM
Knightslugger
Posts: n/a
no, the engine was designed to use unleaded fuel. Leaded fuels were initially designed to help soften the blow caused by Valves slamming into the head. with today's machining technology and manufacturing processes, it's now no longer necessary, and leaves nasty deposits in places you'd rather not have deposits. is a tank going to harm your engine? I donno, guess we'll find out... If the 101 number is the Octane number the fuel has, you're going to experience loss of power until you fill up again with 87. 101 is harder to burn than 87 in an engine designed to run 87. a 101 would be suitable for a car that runs with twin 18psi turbos with hot cams and high compression pistons.
post #7 of 53 (permalink) Old 04-02-2007, 04:09 PM
raptor's Avatar
Forget the octane rating - would you buy paraffin and put it in your bike? Thats what aviation fuel is - ultra-pure paraffin. It'll wash the oil off the bore - more wear and tear. 101 octane petrol is completely different to 101 octane aviation fuel.
"Help look after a$$hole rookies so they can become a$$hole bikers!"
"You appear intelligent, but when you open your mouth, the effect is spoiled"
'03 CBR600RR Black (and silver)
Micron stainless steel slip-on pipe
Dark MRA double bubble screen
Clear headlight lens covers
Home-made Ultra-bright white
Third-Eye and blue Crazy-Eyes
16/45 sprocket setup
raptor is offline
post #8 of 53 (permalink) Old 04-02-2007, 05:58 PM Thread Starter
well my dad has been running the stuff in his race car with 11.75 CR for years and no problems, plus these bikes run better the higher the octane, yes they can run on 87 but the performance suffers if you dont believe me just run 87 for 2 weeks then full up with premium if you dont see a difference then you have a problem, plus with 12 to 1 CR going a little bit higher is cant hurt, i dam near at sea level and i know i can tell a diffence. and no the fuel looked like regular fuel absoultly NO blue tint. plus av gas is not parafin, it is oil that is more refined not just wax that is more refined, parafin is an unwanted byproduct of the reining,
Robebob is offline
post #9 of 53 (permalink) Old 04-02-2007, 06:23 PM
all the bad info....someone please kill me...
steelrain is offline
post #10 of 53 (permalink) Old 04-02-2007, 06:44 PM
Knightslugger
Posts: n/a
HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHAHAHAHAHAAAAAA AAAAAAAA
EEHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH BWAAAAAAAAHAHAHAHAHAHA! OMGOMGOMGOMGOMG..... *pant wheeze*
Who's been feeding you this crap!?! seriously, you can't get any more incorrect than this post! except maybe the aircraft gasoline part... that''s outside my field of knowledge.
let me help:
12:1 CR isn't that high, The CBR600RR powerplant was designed to run 87 PON, i get better EMPG with 87 PON than 91 PON ANYDAY therefore more power is delivered to the ground, higher octane fuels CAN hurt by leaving unburned fuel deposits everywhere from your engine oil to your valve seats to your O2 sensor, Blue tinted exhaust fumes indicate MOTOR OIL consumption, and IF you're talking about JP8, that's just ultra refined kerocene and nothing more.
~FIN~
post #11 of 53 (permalink) Old 04-02-2007, 06:59 PM Thread Starter
well wtf do you call high CR 12 to 1 is the highest i have ever seen possible on pump gas, plus the bike just retards the timing to compensate for the low grade fuel and advances it for the higher stuff, yea sure higher can hurt stuff but not 100, definately 114 but thats designed for 15 to 1 and higher
getting close to a diesel there at 18 to1 and when i said blue tint, i wasnt talking about exhaust, if you knew anything about fuels you would know some grades of fuel have dye in them like 100LL jackass
Robebob is offline
post #12 of 53 (permalink) Old 04-02-2007, 07:06 PM
Feedback Score: -1 reviews
Just get U4 race gas. It's made by VP and it ain't cheap, but if you're looking for a kick in the ass, that'll do it. It smells good when you burn it too!
Since when does more MPG translate to more power to the ground???
CW AF 03 is offline
post #13 of 53 (permalink) Old 04-02-2007, 07:09 PM Thread Starter
finally a usefull answer
Robebob is offline
post #14 of 53 (permalink) Old 04-02-2007, 07:31 PM
Knightslugger
Posts: n/a
Dude, according to the engineers who built this motorcycle's powerplant at Honda R&D, they suggest a 91 RON, 87 PON, or an 85 MON Gasoline fuel, it's as simple as that. I know of no ECU that can determine the GRADE of fuel being injected into the cylinder, only if the fuel that went in last detonated prematurely. If you've got a dyno around, run a tank of 87 for power, then a tank of that super awesome 114. you'll see a drop in power, i guarantee.
Better fuel Economy means it takes less fuel per intake stroke to do the same amount of work. when more work is to be done, more fuel is required. if i can do the same amount of work with less fuel, that means i'm producing more energy with less fuel. if i were to match the fuel levels, i'd be making more. of course, all things being the same otherwise. understand?
post #15 of 53 (permalink) Old 04-02-2007, 07:58 PM
Hitz eit from z back
600rr Rider's Avatar
Just note: if you run u4 you will have to get the bike mapped because u4 will make the bike run leaner and mapping will correct this. +1 U4 does smell good all most makes the price tag go away.
600rr Rider is offline
post #16 of 53 (permalink) Old 04-02-2007, 08:21 PM
AAAGHHh..
u4 is gone, no more, once the current stocks are gone its gon. U4.1 sa replacement and is not a drop in for u4 you will cook up the motor if you do.
further more any gains you get with out tuning he bike to the fuel are trivial.
post #17 of 53 (permalink) Old 04-02-2007, 08:52 PM
ifallssmiley's Avatar
You're just wasting your money dude buying that crap. Unless you've done any work onto your bike, your motor was designed to run on 87-91 octane fuel. Ask ANY engine builder about using higher octane fuel then recommended and they tell you the same thing. Instead of sitting on this forum and arguing your case that back in the day your awesome cousin Ray-Ray told you it made more power, take 2 minutes to search this subject on the net, I think you'll be suprised.
ifallssmiley is offline
post #18 of 53 (permalink) Old 04-02-2007, 09:15 PM
No more U4?!? Crap. That's all I run in my race bike! Can't wait to get it remapped with $50-60 worth of gas in the tank...
CW AF 03 is offline
post #19 of 53 (permalink) Old 04-02-2007, 11:45 PM
Shaggs2Dope's Avatar
Images: 4
we put 100 octane aviation unleaded in some cars and minivans when we run outta gas at the airport, and have had NO problems. Just make sure its 100 unleaded, its like running 92 with octane boost. Sometimes you run outta gas on the fuel light and just need a bit to get to a gas station, it runs smoothe too.
I just like the smell when you burn it, or just splash a gallon in the tank, if you have anything else, the octanes don't mix, but it still has that RACEGAS/Jetfuel smell
and higher octane=worse mileage, higher resistance to detonation
Aww, they love each other, but are Jealous of who gets my attention.
Shaggs2Dope is offline
post #20 of 53 (permalink) Old 04-03-2007, 12:20 AM
gee
Overpaid South Pacific Barista overactive ADHD crew off their meds!!
gee's Avatar
are any of you guys fuel engineers or engine designers....
just a question not an attack, not that a degree means ya know everything.... but there are many urban myths on the fuel question........
gee is offline
post #21 of 53 (permalink) Old 04-03-2007, 01:38 AM
ilangsfs's Avatar
Myth or not, I love the smell of JP8 exhaust. That is all.
Originally Posted by Meatwad
I've never travelled through time, but I've farted my way out of an elevator.
2004 CBR600RR
6000K HID for the Low Beam
Micron Exhaust
Vortex 15/43 520 Conv
ilangsfs is offline
post #22 of 53 (permalink) Old 04-03-2007, 02:08 AM
scoRRpion's Avatar
Some of you guys are talking jet fuel here, I'm sure the original poster was talking radial engine type gasoline. JP4, JP5, and JP8 are all Jet engine fuels designed for higher combustion temps, the stuff he is talking about is not Kerosene based liked the JP class fuels are.
scoRRpion is offline
post #23 of 53 (permalink) Old 04-03-2007, 10:22 AM
HomerSaurus's Avatar
My buddy ran 110 octane av gas in his 600f4i for years. He claimed he got better performance, but I never noticed anything. It stunk like hell when I was behind him though. He never had any problems and he did it on and off for like 3 years. He mostly did it because he worked at the airport and could get it cheap (or free, I never really asked or wanted to know how he got it).
"It seemed like a good idea at the time."
HomerSaurus is offline
post #24 of 53 (permalink) Old 04-03-2007, 12:38 PM Thread Starter
well i now have it in my tank and i can notice a difference in power, but i can tell its more sensetive to the ECT it has to be above 160 or it does that typical hesitation that it does when its reailly cold at full throttle
Robebob is offline
post #25 of 53 (permalink) Old 04-03-2007, 12:58 PM
HighNoonHonda's Avatar
Hmmmm, maybe someone needs to pass this on to mythbusters??
HighNoonHonda is offline
post #26 of 53 (permalink) Old 04-03-2007, 01:18 PM
scoRRpion's Avatar
I remember reading somewhere that just one tank of leaded fuel in an unleaded run CAR should not cause any problems, but in a bike I'm not sure. Either way you should probably not use it consistantly.
post #27 of 53 (permalink) Old 04-03-2007, 03:39 PM
07 TRACK SLAG!
paul46rider's Avatar
Images: 55
Feedback Score: 16 reviews
i run av gas in my track bike, runs soo clean and smooth. and smells too good.
paul46rider is offline
post #28 of 53 (permalink) Old 04-03-2007, 07:10 PM
as far as i know and what it states in the manual is, use an octane of "ATLEAST"(being the operative word) 86... says to use nonleaded fuels because it can damage the Catalytic converter, and "may cause engine damage"...
post #29 of 53 (permalink) Old 04-05-2007, 09:37 AM
MXRider's Avatar
Feedback Score: 17 reviews
ive seen dyno sheets on high compression mx bikes between pump gas and that vp unleaded oxygen enriched fuel. there was more power from the vp fuel. i think its 98 octane. anyone run that stuff in your rr? also does the 03-06 600rr have a cat? or is it just the 07s.
MXRider is offline
post #30 of 53 (permalink) Old 04-05-2007, 01:49 PM
scoRRpion's Avatar
Is that a serious question?
