Should I replace my engine or rebuild it? - 600RR.net
post #1 of 5 (permalink) Old 04-08-2014, 06:58 PM Thread Starter
Feedback Score: 6 reviews
03 600rr. I got the bike wrecked and it had been sitting outside for a long time. we took the airbox off and looked inside it after buying it and there's a ton of corrosion in the cylinder head and possibly the cylinders too. like rusty watery crap. I cleaned it out best i could with some brake cleaner and a tooth brush, removed the spark plugs and cranked it to remove any left over brake cleaner. put it back together and we have spark and fuel.
did a compression check and it came dismal. 115, 55, 34, 25 was the number we got....
Whats a fair price on a good 03-06 engine and would it be better to get a motor from a running bike rather than rebuild mine? I'd like to do whatever is cheaper of course.. its a track bike with a salvage title so its not worth alot without an engine for sure. i probably wouldn't break even
'12 CBR1000RR - Streets
'09 ZX6R - Track only
Rinzler is offline
post #2 of 5 (permalink) Old 04-09-2014, 03:39 AM
you will find a replacement engine is cheaper.
youngy is offline
post #3 of 5 (permalink) Old 04-09-2014, 04:13 PM
mran556's Avatar
dude just buy one on ebay if you must.. I just picked up a 07 with 5k for $1170 shipped
You can find a higher mileage one for around 800..
2007 Cbr600rr Black
mran556 is offline
post #4 of 5 (permalink) Old 04-09-2014, 09:03 PM Thread Starter
yea. working on a deal with a member about his engine for sale.
Rinzler is offline
post #5 of 5 (permalink) Old 04-10-2014, 05:43 AM
Grimmy's Avatar
I'm currently rebuilding my 03 engine and so far it's cost I would say around 1500 - 2000 which is just crazy and I wish I hadn't started doing it, but on the plus side it's for me really enjoyable and a massive learning experience.
Might be worth totalling all the parts needed not forgetting things like sealing washers and head bolts that need to be replaced as they shouldn't be reused. If you go with honda parts all the little things really do add up to a lot!
So, cost wise a second hand motor is a lot cheaper but what condition is it in?
Grimmy is offline
