HRC Valve Springs - 600RR.net
post #1 of 7 (permalink) Old 04-10-2014, 05:25 AM Thread Starter
Grimmy's Avatar
HRC Valve Springs
Might sound a bit naive but can someone tell me what the benefit is to having the HRC valve springs over the standard honda springs. Do you need these spring when fitting the hrc cams or is there any benefit to fitting the springs with the standand honda cams?
Reason I'm asking is, I've got the option to buy a set of new hrc springs cheap and my head is currently getting a rebuild so it's a good time to buy and fit them if there's a good reason to. Any info would be a great :)
Grimmy is offline
post #2 of 7 (permalink) Old 04-11-2014, 02:41 PM
tuck and roll's Avatar
The only reason you might consider getting them is if your stock springs are out of spec. A good head rebuilder would check them and if there good, there's no possitives to the HRC springs, just slightly harder on seats, lifters and cam, but not much.
tuck and roll is offline
The Following User Says Thank You to tuck and roll For This Useful Post:
Grimmy (04-11-2014)
post #3 of 7 (permalink) Old 04-11-2014, 04:37 PM
Ldn
Ldn's Avatar
Recommended if you get the whole HRC power up package.
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
The Following User Says Thank You to Ldn For This Useful Post:
Grimmy (04-11-2014)
post #4 of 7 (permalink) Old 04-11-2014, 07:00 PM Thread Starter
Grimmy's Avatar
Ok cheers lads. I measured my original springs and they all seem to be well within spec, so no point in buying these HRC ones then even if they are cheap.
Grimmy is offline
post #5 of 7 (permalink) Old 04-13-2014, 06:17 AM
the stock springs are double - inner and outer.
quite often kit springs will be a single spring to reduce weight on the valve allwoing it to rev quicker and higher. they will not last as long as the stock items.
youngy is offline
The Following User Says Thank You to youngy For This Useful Post:
Grimmy (04-13-2014)
post #6 of 7 (permalink) Old 10-07-2014, 03:04 PM
BOTM Winner 10/14
Sh1ft3r's Avatar
I had to take those when I was rebuilding the head of my engine with HRC cams
it's advised to use HRC springs when ugrading your cams with the HRC ones
Sh1ft3r is offline
post #7 of 7 (permalink) Old 01-12-2015, 08:55 AM
DimSTriple's Avatar
If you use higher duration camshafts and want to exctend the rev limit of your bike this is the way to go. We rev our cbr up to 16500rpm using those springs. If your motor is stock, stay with oem springs.
The more I learn,
the less I understand
DimSTriple is offline
