Clutch Suggestions - 600RR.net
post #1 of 22 (permalink) Old 04-12-2014, 11:17 AM Thread Starter
Clutch Suggestions
I'm looking to replace my stock burnt out clutch.
What have you replaced yours with?
How do you like it?
I've searched, found lots of older threads.
Thanks in advance!
cdizzle_996 is offline
post #2 of 22 (permalink) Old 04-12-2014, 11:45 AM
tuck and roll's Avatar
Stock clutch is really good, i have a Hinson slipper, but it uses stock plates in it. Has gone 5 years of racing with redline, heavy slipping, high geared starts with little wear and just a bit of blueing of the steel plates, but no warpage, clutch still works good.
tuck and roll is offline
post #3 of 22 (permalink) Old 04-12-2014, 12:32 PM
Justin69's Avatar
EVO makes a great clutch too. Let me know if you would like pricing.
www.kmmotorcycleleathers.com - Arlen Ness, Dainese, Forcefield,Knox,Teknic, Scorpion,Racer,Leatt
www.kmmotorcycleparts.com - Arlen ness, GPR, RKExcel, OZ, Marchesini, Brembo, Ferodo,Woodcraft, Motozen,Hotbodies, Armour bodies,EVR, Double Dog Moto, Diablo Racing
www.kannichmotorsportsblog.com
Justin69 is offline
post #4 of 22 (permalink) Old 04-12-2014, 04:56 PM
nothing wrong with the stock stuff.
youngy is offline
post #5 of 22 (permalink) Old 04-13-2014, 09:35 AM
EVR slipper clutch here, stock OEM plates. Everything jives well. That's the only thing the cbr is really missing to make it a good package Imo.
400kg is offline
post #6 of 22 (permalink) Old 04-14-2014, 11:48 PM Thread Starter
I've been searching and can't seem to find OEM stuff seems to be sold out everywhere I look.
Anyone wanna point me in the right direction
thanks
post #7 of 22 (permalink) Old 04-15-2014, 03:59 AM
I'd be surprised if your nearest Honda dealer couldn't get them for you within a few days.
youngy is offline
post #8 of 22 (permalink) Old 04-15-2014, 04:47 AM
JohnH79's Avatar
I've just fitted a Suter Slipper clutch in mine with EBC plates. Haven't had chance to test it yet as bike is in pieces waiting for my Ohlins kit to arrive.
It's the one thing I think the CBR was missing from the factory is a decent slipper clutch
Akrapovic full exhaust system with Carbon Hex can, K&N air filter, HRC Bell Mouths, Worked Head, HRC Cams, HRC ECU, Power Commander V, Ignition Commander V, Ohlins Rear shock, Ohlins front fork internals, HRC fully floating front discs, Ohlins Steering Damper, Suter Slipper Clutch, Black swingarm, Rev lights, Digital Gear indicator and Oil temp gauge, braided brake lines, Tail Tidy, Single seat Cowl, Double Bubble screen, flush mount LED indicators, tinted light covers, Honda Averto Alarm & HISS
JohnH79 is offline
post #9 of 22 (permalink) Old 04-15-2014, 04:54 AM
PHXRR's Avatar
barnett is good also
Death Smiles Upon Us All, All One Can Do Is twist The Throttle And Smile Back...........
PHXRR is offline
post #10 of 22 (permalink) Old 04-17-2014, 12:57 PM
thanks
I've got a stock Clutch, With some plates, I'm not sure its all of them i'll have to look. This is if you want the OEM replacement. Mine only has 5k miles on it.
If you are looking for Aftermarket, there are a lot of good slipper clutches out there. The biggest issue you'll run into is what you are willing to pay :)
EDIT: For OEM parts Check out Ronayers
400kg is offline
post #11 of 22 (permalink) Old 04-17-2014, 03:15 PM
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
I've always used OEM plates. They seem to last for years for me.
Just disappointed they don't offer the full clutch rebuild kit, with the steel/friction plates and springs, anymore. You have to buy everything individually.
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #12 of 22 (permalink) Old 04-21-2014, 06:39 PM
twissta's Avatar
I use Ebc superbike kits they are awesome
No problems and they are heavy duty. I have a track only bike
twissta is offline
post #13 of 22 (permalink) Old 04-21-2014, 07:58 PM
OveRReV's Avatar
Images: 16
Honda oem clutch plates for me, my old ones are still up to spec even after a lot of abuse, i installed new ones only because they are thinner to get to the required stack height for the EVR slipper clutch i'm running. don't forget to use stiffer clutch springs to eliminate slippage.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #14 of 22 (permalink) Old 04-23-2014, 04:24 PM
Whitepanda's Avatar
id go OEM i have know a few people that have 250k on there stock clutch
Whitepanda is offline
post #15 of 22 (permalink) Old 04-24-2014, 05:31 AM
Tater S's Avatar
What springs would you suggest?
I'm guessing that stiffer springs means more pressure to overcome at the lever if you don't have a hyd master.
How much does it increase the resistance? Is it something you wouldn't want to do if your putting in a lot of street miles?
__________________________________________________ ____________________________________
Thank you for purchasing a 600rr as your first bike.
The odds are strong that you will successfully add to our classified section and help lower parts prices
Crash Stats: Length of ownership
https://www.600rr.net/vb/showthread.php?t=313730
Tater S is offline
post #16 of 22 (permalink) Old 04-24-2014, 07:45 AM
OveRReV's Avatar
Images: 16
i'm running EBC clutch springs at the moment, it still is holding up after a lot of abuse. i didn't even notice the difference between the stock & aftermarket clutch springs at the lever to be honest, it isn't harder to pull the lever in when i'm downshifting for the corners.
another reason to replace the stock clutch springs is if it has logged in a lot of miles, chances are the springs are no longer within the free length suggested by the manual which happened in my case. they're only less than $20 & it's cheap insurance against burnt clutch plates.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #17 of 22 (permalink) Old 04-24-2014, 04:10 PM
Tater S's Avatar
Thank's. I'll def consider that if I ever have to do work in that area.
Tater S is offline
post #18 of 22 (permalink) Old 04-24-2014, 05:24 PM
+1 to this. I too am running EBC Springs with my EVR Clutch, and notice no different feel at the lever.
400kg is offline
post #19 of 22 (permalink) Old 05-02-2014, 10:06 AM
Don't mean to thread jack but is this a complete kit? I know it says it is but just wanna make sure before I buy. And has anyone had any experience with it? Saw a couple of people say they used the ebc components but mixed with pieces from other brands. Thanks https://www.motomummy.com/clutch/ebc-srk-clutch-kit/
SlowDr1v3r is offline
post #20 of 22 (permalink) Old 05-02-2014, 08:46 PM
Antmc05's Avatar
Feedback Score: 8 reviews
OEM all day in a stock clutch IMO! I have a yoyodyne corsa slipper and it takes different plates. for that i get steels from Barnett and use OEM fibers, amazing slipper clutch!!
CVMA #130
Fox Motorsports Racing Team
Peris Riding School
Perisrs.com
Antmc05 is offline
post #21 of 22 (permalink) Old 05-07-2014, 01:35 AM
redrr308's Avatar
Images: 4
Oem all the way. I have barnett in my race bike right now with zero issues, but that with new oil every weekend and only 500 600 miles on them.
redrr308 is offline
post #22 of 22 (permalink) Old 02-18-2015, 07:51 PM
dreamzboy's Avatar
I know it's almost a year old but how do you know when to replace it? My bike shakes when I reach the freeplay boundary while my friend's bike under 4kmi doesn't. Should I be concern?
dreamzboy is offline
