Running RPMs - 600RR.net
post #1 of 4 (permalink) Old 05-08-2014, 10:01 AM Thread Starter
alexn418's Avatar
Running RPMs
Been having a minor problem lately.
Something went I pull in the clutch when I'm about to shift the RPMs keep going for a couple more seconds.
Not sure what the problem could be. It doesn't happen every time but enough for me to notice.
I thinking about getting a power commander soon and hopefully theta will fix the problem.
Any thoughts?
alexn418 is offline
post #2 of 4 (permalink) Old 05-10-2014, 06:49 PM
AF600RR's Avatar
Are you completely closing the throttle before you even touch the clutch?
Is your throttle tube sticking or not shutting itself completely? Slack on the throttle cables adjusted correctly to have the correct free play?
As it's intermittent, I'm leaning more towards yourself not closing the throttle before your pulling the clutch in....
A Power commander will not solve this "issue".
AF600RR is offline
post #3 of 4 (permalink) Old 05-10-2014, 11:07 PM
mran556's Avatar
What the above poster said. I do it as I find it makes my shifts smoother
2007 Cbr600rr Black
mran556 is offline
post #4 of 4 (permalink) Old 05-11-2014, 03:06 PM
Mbiker's Avatar
Lube throttle cable, check throttle tube for free play, check if bar end is not blocking throttle tube.
Check if butterfly springs are still ok, ie if you pull them open manually that they snap sharply shut
Live to ride!
Build of my 05 600RR; https://www.600rr.net/vb/showthread.php?t=414385
Mbiker is offline
