Any easy upgrades I should make while the engine is out? - 600RR.net
post #1 of 15 (permalink) Old 06-05-2014, 07:51 AM Thread Starter
travr6's Avatar
I am dropping the engine to repair something on the top end.
I do not want to build a full out race engine.
I just want to know if there are any simple mods I should make while the engine is out.
Smog block offs or something like that.
travr6 is offline
post #2 of 15 (permalink) Old 06-05-2014, 02:45 PM
FightingChance's Avatar
Feedback Score: 10 reviews
Yeah, PAIR removal and plates. You can get to the spark plugs real easy, even if it's not time yet, well, you can do it now anyway. Since the throttle bodies are off the engine (assuming they are) you can attach and route new cables (OEM or a whole new quick throttle)... that's all I can think of.
FightingChance is offline
post #3 of 15 (permalink) Old 06-05-2014, 03:29 PM
Put a fuckin turbo on it.
But no really, the PAIR system, and new plugs if you want... Otherwise that's about it. You could power wash it too and clean it all up nice and pretty.
400kg is offline
post #4 of 15 (permalink) Old 06-05-2014, 03:51 PM
Austicus's Avatar
PAIR removal would be easy but still a waste of time IMO. If you don't plan to race and track your time then don't remove it.
Austicus is offline
post #5 of 15 (permalink) Old 06-05-2014, 05:39 PM
mikesx4911's Avatar
I always thought about getting bigger pistons, changing the rods, getting new cams. It proably be fuckn overkill but that be a bad ass motor lol.
mikesx4911 is offline
post #6 of 15 (permalink) Old 06-05-2014, 05:40 PM
Austicus's Avatar
Or you could buy a 1K and still be faster.
Austicus is offline
post #7 of 15 (permalink) Old 06-05-2014, 08:27 PM
Tater S's Avatar
So what would stock 09+ pistons do? I always thought that's probably what helps them get better midrange and maybe a little better top once you bypass the electrical restrictions....Z Bomb
__________________________________________________ ____________________________________
Thank you for purchasing a 600rr as your first bike.
The odds are strong that you will successfully add to our classified section and help lower parts prices
Crash Stats: Length of ownership
https://www.600rr.net/vb/showthread.php?t=313730
Tater S is offline
post #8 of 15 (permalink) Old 06-05-2014, 08:41 PM
The Z-Bomb doesn't give power, it restores power lost as the 09 ECU turns down power in top of the range to meet EURO5 sound/emissions (I believe). That's why the 07-08 gain nothing/aren't used with the Z-Bomb.
post #9 of 15 (permalink) Old 06-05-2014, 10:37 PM
Tater S's Avatar
Correct. I guess I didn't word that good enough.
I think you know what I mean about the pistons.
Tater S is offline
post #10 of 15 (permalink) Old 06-05-2014, 10:46 PM
Oh, my bad. I've never heard of any named, specific difference in the internals but their could be changes - but splitting the cases and doing surgery gets so costly so fast you'd be much better off doing the stuff from the HRC power up kit instead.
post #11 of 15 (permalink) Old 06-06-2014, 01:00 AM
Lots of easy upgrades. Question is how much you want to spend? Cams are easy. Sending the head out for porting is easy. Thinner head gasket for more compression, or shave the head while its getting ported. None of this is cheap usually.
'06 F4i- Yoshimura RS-3C, Racetech springs and valves, Ohlin's rear shock, steel brake lines, 520 conversion. 87k miles and counting.....
'08 600RR- Stripped trackbike. CRG shorty brake lever, goodridge front brake lines
'15 1000RR- weekend toy
------Disclaimer: I can't spell------
bored&stroked is offline
post #12 of 15 (permalink) Old 06-06-2014, 02:08 AM
Tater S's Avatar
From what I understand the piston tops are shaped differently.
Tater S is offline
post #13 of 15 (permalink) Old 06-07-2014, 09:16 PM Thread Starter
travr6's Avatar
I am fixing this bike up to sell so cheap and easy mods.
What is Pair?
Any links to a how -to?
travr6 is offline
post #14 of 15 (permalink) Old 06-23-2014, 09:01 AM
OveRReV's Avatar
Images: 16
just slot the sprockets & advance the cams to give a bit more midrange, i did some work in my motor & got a decent gain but now i'm taking it to the next level & building a superbike spec 600cc engine.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #15 of 15 (permalink) Old 10-07-2014, 03:02 PM
BOTM Winner 10/14
Sh1ft3r's Avatar
HRC cams with valves and valve springs! a valve clearance would be smart to do anyways
Sh1ft3r is offline
