07 cbr600rr Leaking coolant from fuel tank overflow hose?! - 600RR.net
post #1 of 3 (permalink) Old 10-09-2014, 09:14 AM Thread Starter
Gonzalezb404's Avatar
So after looking into it further i realized the coolant leak is coming from the thermostat housing. Is it as easy as replacing the rubber ring and sealing it? What caused this to happen? Will it happen again after i replace the ring and use sealant?
Gonzalezb404 is offline
post #2 of 3 (permalink) Old 10-10-2014, 06:53 AM
BOTM Winner 10/14
Sh1ft3r's Avatar
It is possible the sealant/gasket is broken, if you see that it's leaking from your thermostat housing then probably yes replace the sealant and it should stop leaking
Sh1ft3r is offline
post #3 of 3 (permalink) Old 10-10-2014, 09:10 PM Thread Starter
So I sealed the housing. Soon after a hose connected to the thermostat housing started leaking, so I bought a new clamp, problem fixed. After that the other side of that hose started leaking, same and now fixed. Now a hose connected to the water pump is leaking!!! Why is his happening?! I'm losing my mind! About to buy a new clamp for that hose and see what happens!
