Timing chain tensioner not replaced in time. Here we have consequences... - 600RR.net
post #1 of 11 (permalink) Old 10-17-2014, 06:19 AM Thread Starter
vjs
Seems I should pay attention to a rattle sound inside engine as it should prevent from what I got now... Actually I thought it is a sound from clutch...
Actually it wasn't... Seems timing chain tensioner failed and I got timing chain jumped over and lost timing... Thanks god all the valves are OK. Seems this bike was running a LOONG time with a loose timing chain.
What I wanna say is IF YOU HEAR A RATTLE SOUND FROM RIGHT SIDE OF THE ENGINE YOU SHOULD CHECK IF TIMING CHAIN TENSIONER WORKS PROPERLY...
ID:	140978   Click image for larger version
ID:	140986   Click image for larger version
vjs is offline
post #2 of 11 (permalink) Old 10-17-2014, 06:45 PM
etxx's Avatar
holy smokes..!
did you take the head off and look at the valves and pistons? i would be amazed you didn't kiss a couple if you jumped timing.
etxx is offline
post #3 of 11 (permalink) Old 10-17-2014, 09:02 PM
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
Ouch. A guy lose his at a trackday last year. The sounds it made were not good.
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #4 of 11 (permalink) Old 10-19-2014, 09:05 AM Thread Starter
vjs
Originally Posted by etxx View Post
holy smokes..!
Head is off now. Clean. No any signs of damage. Tested valves if they are bent. All of them are OK. Seems I was lucky one...
Waiting for a new manual timing chain tensioner, runners and timing chain.
vjs is offline
post #5 of 11 (permalink) Old 10-19-2014, 09:08 AM Thread Starter
vjs
That's what I supposed to say with this thread - do not waste time when You get a rattle sound on right side of the engine. Just fix/replace timing chain tensioner.
vjs is offline
post #6 of 11 (permalink) Old 12-09-2014, 11:44 PM
hxccalinip's Avatar
Hey i have probably the same noise.
When you had your head off the block, was the engine completely out of the frame?
If not, can you replace the timing chain and all chain guides without removing engine from frame?
I haven't been able to find anything or anyone removing an engine from frame or how to replace timing chain with guides.
hxccalinip is offline
post #7 of 11 (permalink) Old 12-10-2014, 12:43 AM
You can do a timing chain, tensioner and guides with the engine in frame. All you need to do is pull the valve cover and clutch cover.
wibbly is offline
post #8 of 11 (permalink) Old 12-10-2014, 12:25 PM
hxccalinip's Avatar
I am assuming you would need to remove the cam shafts out to replace timing chain?
post #9 of 11 (permalink) Old 12-10-2014, 02:04 PM
Yup. The cams come out. But you can easily do this with the engine in
wibbly is offline
post #10 of 11 (permalink) Old 12-16-2014, 10:35 AM
Mbiker's Avatar
But i would advise you first to check and change the tensioner.
Normally the noise should be gone then.
Live to ride!
Build of my 05 600RR; https://www.600rr.net/vb/showthread.php?t=414385
Mbiker is offline
post #11 of 11 (permalink) Old 12-16-2014, 10:44 AM
Mbiker's Avatar
Live to ride!
Mbiker is offline
