Crankcase Separation/Mating - 600RR.net
post #1 of 11 (permalink) Old 11-04-2014, 11:09 AM Thread Starter
I've got an 05 600rr that has ~40K miles on it. With winter coming up (as well as more free time as I will only have work- not work AND school), I have been thinking of swapping out the motor or rebuilding mine. After some research on ebay, it may be hard to find a complete used bottom end. I was trying to avoid separating and re-mating the crank case by just replacing any external seals and rebuilding the top end.
I may not have that option after looking at ebay for a while, so have any of you separated and mated the crankcase on this bike before? Is it a PITA? The lead service tech said it may not be worth it.
(PS: Does the 03-04 bottom end work with an 05-06 top end? I know they have different part numbers, but I figured I might ask, anyway.)
Thanks!
Thatdudeguybro is offline
post #2 of 11 (permalink) Old 11-04-2014, 01:15 PM
What leads you to believe it needs a rebuild?
wibbly is online now
post #3 of 11 (permalink) Old 11-04-2014, 03:40 PM Thread Starter
Not really anything other than high mileage. Its more of me wanting to prevent any issues due to high mileage (read: peace of mind, whether its real or just perceived) and being bored over winter, as well as getting to know the CBR better.
post #4 of 11 (permalink) Old 11-04-2014, 04:23 PM
mran556's Avatar
Idk no man theres no need for anything your wanting to do.. youll get no peace of mind your motor is good for well over 40k lol
2007 Cbr600rr Black
mran556 is offline
post #5 of 11 (permalink) Old 11-04-2014, 05:14 PM
I promise you that once you crack into it you will constantly worry about the work you did. Nobody can assemble that engine as well as Honda did at the factory. Once it's been opened it will never be the same. 40k isn't exactly miled out. If it still runs strong and doesn't use oil there's no reason to rip it apart
post #6 of 11 (permalink) Old 11-04-2014, 10:47 PM Thread Starter
Fair enough haha
post #7 of 11 (permalink) Old 11-05-2014, 10:00 AM
BOTM Winner 05/15
cbr6racr's Avatar
Feedback Score: 28 reviews
Define "High Mileage".....
-Chad
"Logically, any motorcyclist can do 60* of lean. The trick is coming back up again." - Neal Spalding
cbr6racr is offline
post #8 of 11 (permalink) Old 11-12-2014, 04:22 PM Thread Starter
"High Mileage": #'s much larger than what I am used to seeing on a sport bike. My 'high mileage' may very well not actually be high mileage. In this case, I'm talking a little over 40k.
post #9 of 11 (permalink) Old 11-12-2014, 04:46 PM
Keenan's Avatar
I have a 2005 cbr600rr with 110,000kms and she runs strong and doesn't burn any oil. Only engine work I have ever had done was valves where checked and still in spec at 90,000km and had the replace the cam chain Tensioner. Went with the APE manual one.
2005 Honda CBR600rr Black\Tribal Flames
Yoshimura RS-5
-1 Front
Pazzo Shortys
Proton Flush Mounts
Gpr v4
Frame Sliders
Swingarm Spools Sliders
Zero Gravity DB
DIY FE
DIY Led Passenger Pegs
LED Plate Bolts
Sportech Tank Pad Skull Black
Stomp Grip
Keenan is offline
post #10 of 11 (permalink) Old 11-12-2014, 05:19 PM
BOTM Winner 05/15
cbr6racr's Avatar
I'm at 80,000 track and street miles on my RR, no burning, still pulls hard, sounds healthy. Only had to adjust the valves once. These motors are tanks. Keep the oil changed, and up to date on valve checks, and they'll go for a long time.
-Chad
cbr6racr is offline
post #11 of 11 (permalink) Old 11-14-2014, 01:49 AM
OzMoto's Avatar
I just clicked over 40,000km on my 03 CBR. Only thing I need to get is CCT. Just going to get an APE one.
Ride carefully - You are invisible.
FB | YT
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R
Sold: 2001 NSR150SP | 2012 CBR250R
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
