Fuel in airbox? - 600RR.net
post #1 of 8 (permalink) Old 03-13-2015, 11:23 PM Thread Starter
Fuel in airbox?
So I took apart my airbox to change out the air filter and put in the short velocity stacks and noticed that there was a build up of fuel on the left side of the airbox. Is this normal to have some fuel(silver dollar sized pool) in or around the airbox or is my injector deciding to spray sideways?
Deenutz is offline
post #2 of 8 (permalink) Old 03-14-2015, 12:44 AM
sure sounds like leak....airbox s/b dry....
keep posting details....
park the bike outside!
and: get a fire extinguisher handy. (rated ABC!).....
drain/clean airbox, remove airfilter ......
and turn key to start fuel pump prime... be ready to turn off at any moment.
look for leaks in upper injectors from the fuel rail...
DO NOT start bike.
Maybe Wibbly, NICO OveRRev or another Mage will answer.....i'm just a punter...
Last edited by tary preisser; 03-14-2015 at 12:57 AM. Reason: need fire extinguisher for this..!
tary preisser is offline
post #3 of 8 (permalink) Old 03-14-2015, 01:45 AM
cbrkat28's Avatar
Was the bike on both front & rear stands when you discovered this, just the rear stand, or no stands at all? I think the upper set would have to be leaking and that's not something I'd want to have.
1971 Volkswagen 1302 (02.19.2015 - )
For Sale:
https://www.600rr.net/vb/153-07-13-rr...0rr-c-abs.html
cbrkat28 is offline
post #4 of 8 (permalink) Old 03-14-2015, 02:24 AM
are you 100% it's fuel?
with the bike sitting on the kickstand it's natural for things to collect on the left side. usually this is oil though, it comes into the airbox naturally from the crank case breather, and will end up on the left side when the bike sits on the side stand.
for fuel to be there and not evaporate is a bit suspicious. the only way i could see fuel ending up there would be a leaking shower injector.
with the airbox lid off, just turn on the key and let the pump prime, if you see fuel coming from one of the shower injectors then there's your issue. i don't see any other way for fuel to pool in the airbox.
wibbly is offline
post #5 of 8 (permalink) Old 03-14-2015, 02:33 AM
cbrkat28's Avatar
Fuel has a fairly distinctive smell and the evap aspect did cross my mind, I wonder if an injector can malfunction such that power loss causes like a fuel incontinence for lack of a better term.
For Sale:
cbrkat28 is offline
post #6 of 8 (permalink) Old 03-14-2015, 02:35 AM
the guy will just have to see. should be a very simple test.
wibbly is offline
post #7 of 8 (permalink) Old 03-16-2015, 11:26 AM Thread Starter
So been working on my bike, doing the short velocity stacks, air filter and air box mod. I will prime the bike today when I get home and see if it has a fuel leak. But now that I read this I think it was a mix of oil and fluid. So hope it is just that but will keep you guys posted.
Deenutz is offline
post #8 of 8 (permalink) Old 03-16-2015, 01:13 PM
FightingChance's Avatar
Feedback Score: 10 reviews
I had a tiny bit of oil smudge in the corner of my airbox as well last time I opened it up.
FightingChance is offline
