Torque Wrench Question - 600RR.net
post #1 of 34 (permalink) Old 04-05-2015, 12:13 PM Thread Starter
BOTM Winner Jan 2015
shinfo's Avatar
So I got a torque wrench a few months ago and noticed that the units are "Foot-Pounds" and the service manual I have gives the units in "lbf-ft", so pounds-foot I assume. I see there is a difference but could someone explain this a little better to me? Thankfully the wrench also has nm on it, but the range of it isn't what I had expected it to be due to my error of not knowing there was a difference. All of the wrenches I can find on US websites and in store are foot-pounds and I can't find one that is pounds-foot. I'm going mad.
https://40.media.tumblr.com/68b9f92683e3e0506dd727af79363281/tumblr_ntyw0v9hrk1ufoouto1_500.jpg
shinfo is offline
post #2 of 34 (permalink) Old 04-05-2015, 12:15 PM
Torque is the product of force (lbs, newtons) and distance from the fulcrum (inches, feet, meters)
So the units are ft lbs, pound feet, inch pounds, newton meters etc.
Its all the same thing
wibbly is offline
post #3 of 34 (permalink) Old 04-05-2015, 12:25 PM Thread Starter
shinfo's Avatar
Right, but what is the difference between foot pounds and pound feet?
shinfo is offline
post #4 of 34 (permalink) Old 04-05-2015, 12:39 PM
Nothing.
What's the difference between 2 x 6 and 6 x 2
wibbly is offline
dehingst (04-11-2015)
post #5 of 34 (permalink) Old 04-05-2015, 12:56 PM Thread Starter
shinfo's Avatar
Originally Posted by wibbly View Post
Nothing.
Well that's what I thought, however in the service manual it states that the torque value for the oil drain bolt, for example, is "30 Nm (3.1 kgfm, 22 lbfft)".
So my torque wrench that is 20-150 foot-pounds should be able to do the job if lbfft and foot-pounds are the same thing. However, when looking at the Nm markings on the same wrench, it starts at 33.9, which would put this wrench 3.9 Nm above the value needed to tighten this properly.
shinfo is offline
post #6 of 34 (permalink) Old 04-05-2015, 04:42 PM
mran556's Avatar
Huh dude when stuffs in nm i just ask my android what 10 nm to foot pounds and it tells me. Same with inch pounds etc..
2007 Cbr600rr Black
mran556 is offline
post #7 of 34 (permalink) Old 04-05-2015, 05:54 PM
Its just a scale. It probably has lbft one side and nm on the other correct? I bet it has lbft on the front and nm on the back right? So to get the zero line on the nm division you need to turn the handle half a turn up from the ft lb scale. To keep the linearity with both scales using the same divisions on the handle, the nm scale will have to be offset vs the lbft scale
Got it? If your wrench does 20-150 then set it at 22 and get it done
wibbly is offline
post #8 of 34 (permalink) Old 04-05-2015, 08:20 PM Thread Starter
shinfo's Avatar
I'll take a picture of it when I get home.
shinfo is offline
post #9 of 34 (permalink) Old 04-05-2015, 08:52 PM
Either way. A lbft is the same as a ftlb. For clear reasons
wibbly is offline
post #10 of 34 (permalink) Old 04-08-2015, 08:58 PM
teedubyaw's Avatar
Nothing.
Is that serious?
2015 R1
teedubyaw is offline
post #11 of 34 (permalink) Old 04-08-2015, 10:53 PM
I wouldn't necessarily trust a 20-150 wrench to pull 20lbs accurately. It's probably gonna be tighter than 20
It's suggested to only use the within 10% (might be higher but then it'd be a waste of a torque wrench amirite?) of the limit
ztc278 is offline
post #12 of 34 (permalink) Old 04-08-2015, 11:28 PM
Originally Posted by teedubyaw View Post
Is that serious?
Well... Given the original post I think its relevant.. Dont you?
wibbly is offline
post #13 of 34 (permalink) Old 04-09-2015, 12:05 AM Thread Starter
shinfo's Avatar
I don't think it's as clear as you make it out to be. There seems to be a fair amount of mixed opinion on the Internet as well. Some saying they are totally different, while some saying they are the same. I seem to think they are different since the conversion doesn't match up on the bottom unit of the torque wrench.
shinfo is offline
post #14 of 34 (permalink) Old 04-09-2015, 09:25 AM
You can be as skeptical as you want, torque is the product of force and distance. Only the units can change. If you use pounds as your unit of force and feet as your unit of distance then it doesn't matter in the slightest how you multiply them together, the result is the same.
wibbly is offline
post #15 of 34 (permalink) Old 04-09-2015, 06:54 PM
cbrkat28's Avatar
You're good dude, the person that wrote the ad isn't the engineer that designed the wrench.
...semantics
I've heard the middle 75% is what they should be used for; so 12.5% above the lower limit and 12.5% below the upper limit.
I'm not trying to start a debate on this but 1/3 is not the same as 3/1...can we agree it's just semantics?
1971 Volkswagen 1302 (02.19.2015 - )
For Sale:
https://www.600rr.net/vb/153-07-13-rr...0rr-c-abs.html
cbrkat28 is offline
post #16 of 34 (permalink) Old 04-09-2015, 07:09 PM
Torque is the PRODUCT of force and distance. Not the quotient. Your argument is invalid
wibbly is offline
post #17 of 34 (permalink) Old 04-09-2015, 07:16 PM
cbrkat28's Avatar
I know you like arguing with me but the unit is generally depicted as lb/ft, implying division.
For Sale:
cbrkat28 is offline
post #18 of 34 (permalink) Old 04-09-2015, 08:06 PM
So we are basing this all on incorrect descriptions?
wibbly is offline
post #19 of 34 (permalink) Old 04-09-2015, 08:11 PM
cbrkat28's Avatar
That's my theory...do you think the marketing department really knows what the difference is between the way the ad was worded and what the units of measure actually mean mathematically?
For Sale:
cbrkat28 is offline
post #20 of 34 (permalink) Old 04-09-2015, 08:59 PM
I'm saying it doesn't matter. A foot pound is a pound foot. I don't see how this thread is still going
wibbly is offline
post #21 of 34 (permalink) Old 04-09-2015, 09:04 PM
cbrkat28's Avatar
You and I squabbling over semantics but I don't think that's necessary anymore.
For Sale:
cbrkat28 is offline
post #22 of 34 (permalink) Old 04-09-2015, 09:46 PM Thread Starter
shinfo's Avatar
It's getting heated up in here lol
shinfo is offline
post #23 of 34 (permalink) Old 04-09-2015, 09:47 PM
cbrkat28's Avatar
Fvckin marketing lol
For Sale:
cbrkat28 is offline
post #24 of 34 (permalink) Old 04-10-2015, 12:03 AM
BOTM Winner 07/16
rinonz's Avatar
Wikipedia answer: http://en.wikipedia.org/wiki/Pound-foot_%28torque%29
I'm a metric kind of guy so always use Nm which has less ambiguity :)
rinonz is offline
post #25 of 34 (permalink) Old 04-10-2015, 12:13 AM
cbrkat28's Avatar
I use metric on my bike because it was designed and built in metric...makes sense to me anyway.
For Sale:
cbrkat28 is offline
post #26 of 34 (permalink) Old 04-10-2015, 04:22 PM
Sorry but that's like saying miles per hour and hour per mile is different.
It would essentially be the same just incredibly stupid to measure that way.
It's not division
It's a meaaurement
ztc278 is offline
post #27 of 34 (permalink) Old 04-10-2015, 05:02 PM
cbrkat28's Avatar
I can't tell if y'all are just trolling me or completely inept mathematically...I really hope it's just trolling.
For Sale:
cbrkat28 is offline
post #28 of 34 (permalink) Old 04-10-2015, 09:39 PM
blkcavy98's Avatar
blkcavy98 is offline
post #29 of 34 (permalink) Old 04-11-2015, 01:58 PM
PdubRR's Avatar
+1. If the bolt spec & tool settings are in metric why the extra step to convert?
PdubRR is offline
post #30 of 34 (permalink) Old 04-11-2015, 04:06 PM
cbrkat28's Avatar
Maybe someone's torque wrench doesn't have both units of measure?...that's the only reason I have.
For Sale:
cbrkat28 is offline
