Cam Chain Tension (CCT) Manual Adjusters - 600RR.net
post #1 of 9 (permalink) Old 05-04-2015, 04:18 PM Thread Starter
My bikes equipped with the MANUAL aftermarket cam chain tensioner (CCT). I've been told by few locals that the OEM tensioner is unreliable and recommend to continue using what I have rather than the auto adjust CCT.
Give me you input guys!
fezz is offline
post #2 of 9 (permalink) Old 05-04-2015, 04:31 PM
DoomCue's Avatar
Personal choice. Yes, the OEM will eventually fail, but it's cheap enough that it falls into the inexpensive maintenance category for me. The manual ones are just that - manual. Personally, I chose to go with OEM because I'd rather not have to make adjustments. That requires pulling the fairings off for me. My time is worth $50 every few years to me.
DoomCue is offline
post #3 of 9 (permalink) Old 05-04-2015, 04:41 PM
DoomCue's Avatar
Oh yeah, not to mention that if you set the manual CCT incorrectly, bad things can happen. If the OEM CCT hasn't failed, it will always be at the correct tension.
DoomCue is offline
post #4 of 9 (permalink) Old 05-04-2015, 09:49 PM
BOTM Winner 09/15
Buckley.S's Avatar
My experience with the OEM CCTs hasn't been good, been through 2 in 12k miles. I've got the APE manual one on now and it's much better, nothing to break and you just adjust it as you need. Only downsides are that you do have to add checking it to the list of monthly checks (or weekly if you ride a lot) and make sure you don't over tighten it because if you do you can seriously damage things.
You only go as fast as you twist the throttle.
My build thread: https://www.600rr.net/vb/showthread.php?t=302170
www.carbon-hut.co.uk
Buckley.S is offline
post #5 of 9 (permalink) Old 05-05-2015, 12:47 PM Thread Starter
What happens if it's loose? The last CCT I had on the motor which is now replace, I went 15k miles before needing, or concerned on adjustments. Is this normal or am I taking too long on adjusting them?
How bad, severe, is it to the motor when chain is loose?
fezz is offline
post #6 of 9 (permalink) Old 05-05-2015, 01:11 PM
dagg92's Avatar
You'll hear the cam chain slapping around if it's loose. You just really don't want the chain to jump a tooth and ruin timing and possible damage a valve. I haven't had to change mine yet at 25k. Had the bike since 14k...
dagg92 is offline
The Following User Says Thank You to dagg92 For This Useful Post:
fezz (05-05-2015)
post #7 of 9 (permalink) Old 05-05-2015, 03:56 PM
I just replaced mine with another oem one and the noise is still there. Per nico, it could be a defective oem or the chain guides which would sucks since my bike only has 8000miles. I don't know if I should get another oem (and risk to be DOA again) or go manual
blarf is offline
post #8 of 9 (permalink) Old 05-05-2015, 07:56 PM
BOTM Winner 09/15
Buckley.S's Avatar
Even a new OEM part can be faulty, I just don't trust them anymore and prefer to do it myself with a manual CCT.
With regards to how often to adjust it and how much, when the chain starts to rattle enough to notice when I ride I give it a tighten. Only a 2 minute job so do it after a ride or as it's warming up. Tension wise, you want to adjust it so it's just enough to stop the chain noise so I have the bike idling, loosen the APE CCT back to hear the rattle and then tighten it to the point where I can't quite hear it. You don't want the chain to skip a tooth as mentioned but you also don't want to over do it.
post #9 of 9 (permalink) Old 06-15-2015, 09:16 PM
manual CCT are a pain. Not worth bothering with. People often think their CCT has gone bad when they hear a soft tapping sound when really eveything is fine and it's just the chain and valvetrain doing what it needs. A tappy valve is a happy valve. I've seen people have a lot more problems with oil leaks and CCT failure from manual tensioners than from OEM.
WMRC #386
drewnabobber is offline
The Following User Says Thank You to drewnabobber For This Useful Post:
tary preisser (06-16-2015)
