copper sparkplugs in iridium specified engine? - 600RR.net
post #1 of 15 (permalink) Old 06-08-2015, 05:27 AM Thread Starter
Husted86's Avatar
Hi all,
As far as I know the reason for Iridium spark plugs is specified in a stock engine is because of the service interval.
Furthermore Iridium is more resistant on high performance engines (with much higher compression than stock).
I will postulated that copper is the most electric leading material for spark plugs and if the service interval doesn't matter for me. I think I will choose those copper ones. Of course with same thread size and heating range as original specified. They are cheaper to.
So here is my question: Have anyone tried this or does anyone have some concerns about it?
My bike is a cbr600rr 2007 specified with NGK IMR9-9HES
and I will like to use NGK CR9EIX
I am a new user, looking forward to hear your comments. Thanks in advance.
Husted86 is offline
post #2 of 15 (permalink) Old 06-08-2015, 07:09 AM
Miweber929's Avatar
I've done it with other bikes in the past that called for iridium and have heard, felt and seen no difference in using the copper ones.
Having said that I personally buy what is called for by the manufacturer every time now; the wallet sting only last a short time and digging them in and out sucks enough I don't want to do it any more than I have to.
Keep in mind, though, the plugs are tiny, the head is aluminum and the thread pitch very fine so they are easy to cross thread and over tighten. The more you take them in and out the easier it is to get it wrong and, well, you know the rest.
Mike
Miweber929 is offline
The Following User Says Thank You to Miweber929 For This Useful Post:
Husted86 (06-09-2015)
post #3 of 15 (permalink) Old 06-08-2015, 07:38 AM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
This is so true.
TheX is offline
The Following User Says Thank You to TheX For This Useful Post:
post #4 of 15 (permalink) Old 06-08-2015, 08:06 AM
thro's Avatar
Iridium is specified because changing plugs is a pain in the ass.
Why do you want to use copper? Iridium last many many times longer.
2007 Honda CBR600RR: Akrapovic slip-on, HEL braided lines, ASV shorties
2009 Honda CBR1000RR Repsol: Sato rear-sets, Taylormade slip-on, Pazzo Shorties
1996 Suzuki RGV 250 - Arrow pipes
thro is offline
The Following User Says Thank You to thro For This Useful Post:
post #5 of 15 (permalink) Old 06-08-2015, 09:33 AM
Miweber929's Avatar
Not to answer for the OP but my guess is while he is mentioning the electrical properties of copper, it's cost: copper plugs are like $5 each, iridium are about $20 each.
Mike
post #6 of 15 (permalink) Old 06-09-2015, 01:54 AM Thread Starter
Husted86's Avatar
Thanks everybody.
The reason why i considering using copper ones is that they are cheaper but also because in theory the spark should be better. Copper is a better electric conductor then most materials including iridium and platinium.
So performance wise it should be better. Copper is less resistant to heat and wear therefore the service interval is lower. But for me it is no problem to change them every season.
Thanks for the inputs. as far i can see i am not completely wrong ;)
Husted86 is offline
post #7 of 15 (permalink) Old 06-09-2015, 12:42 PM
thro's Avatar
Mike
Yeah, and iridium last like 8x as long. It's a no brainer.
But hey, if you like taking your bike apart to replace spark plugs for fun, go for it.
I'd rather save the money and stop wasting my time, to boot.
edit:
you know it's only iridium on the tip, right?
#justthetip
thro is offline
post #8 of 15 (permalink) Old 06-09-2015, 01:33 PM
FightingChance's Avatar
Feedback Score: 10 reviews
The performance envelope of the engine and ECU is designed around a controlled plug; I'd never go outside the material or range unless I had engine work done and knew what I was doing.
FightingChance is offline
post #9 of 15 (permalink) Old 06-09-2015, 02:28 PM
BOTM Winner 07/14
tornado bait's Avatar
Images: 17
Feedback Score: 12 reviews
When Erion built my engine they installed copper plugs.
cr9ek if anyone is interested in the exact plug
Vortex, Tucker Rocky, Speed & Strength, BikeMaster, E4S
Cafe Racer Inc.
Tornado Bait Racing
tornado bait is offline
post #10 of 15 (permalink) Old 06-09-2015, 05:03 PM
OzMoto's Avatar
I would use whatever is recommended in the service manual.
Ride carefully - You are invisible.
FB | YT
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R
Sold: 2001 NSR150SP | 2012 CBR250R
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
post #11 of 15 (permalink) Old 06-13-2015, 06:58 PM
OveRReV's Avatar
Images: 16
NGK CR9EIX is an iridium tipped spark plug just like the original NGK IMR9C-9HES, I've used the CR9EHIX9 before switching to the original after it started to misfire, bought a CR10EIX plugs because I need colder for my modded engine.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #12 of 15 (permalink) Old 06-13-2015, 10:44 PM Thread Starter
Husted86's Avatar
So there is no difference between those two?
Husted86 is offline
post #13 of 15 (permalink) Old 06-13-2015, 10:54 PM
Bridge_Jumper's Avatar
Lol you say that now..... wait until you try and change them with the engine still in the bike.....
2006 Honda CBR600RR Black Tribal Edition
2W1R - IceTitan
Bridge_Jumper is offline
post #14 of 15 (permalink) Old 06-13-2015, 11:01 PM
Maynard
JohnDoubleR's Avatar
Nitpicking here. I'm pretty sure you're talking about the IMR9E-9HES not IMR9-9HES because the latter isn't listed in my NGK catalog. The IMR9C-9HES are a tad cheaper than the IMR9E-9HES..
Otherwise all IMR9E-9HES, IMR9C-9HES, CR9EIX and CR9EHIX9 have iridium tips and copper core material
2W1R
2012 M1100 EVO
JohnDoubleR is offline
post #15 of 15 (permalink) Old 06-14-2015, 08:03 AM
OveRReV's Avatar
Images: 16
internally there are none, externally it's quite obvious.
NGK CR9EIX & CR10EIX are full thread sparkplugs.
the last 2 are 2/3 thread sparkplugs which are exclusive for Honda CBR.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
