Can you tell a 03/04 engine from a 05/06? - 600RR.net
post #1 of 15 (permalink) Old 09-13-2015, 02:13 PM Thread Starter
Hi Guys. I bought this bike used and abused. Harness is chopped. Fairings dont line up etc..
My cluster only shows MPH because wires are cut. I purchased a 03/04 upper harness and it didnt fit. Completely different. Now I have concerns that my 03/04 Frame MAY have a 05/06 engine and thats the reason that the harness I ordered for a 03 was incorrect.
Is there a way to find an engine ID that I can run to find out the year? Or maybe one of the gear heads can tell by a visual difference?
Any help is greatly appreciated.
ID:	164050   Click image for larger version
RR.Bran is offline
post #2 of 15 (permalink) Old 09-14-2015, 11:27 AM Thread Starter
Bump Bump Bump
RR.Bran is offline
post #3 of 15 (permalink) Old 09-14-2015, 12:48 PM
RothmansRR's Avatar
From what I've read before, the external appearance is the same. Only some minor modifications were done internally. So you'd have to be able to open it up, and even then you'd need to know how to tell apart their internals. Maybe the engine # will reveal some details, but I'm not sure.
What do you mean by upper harness anyway, do you mean the harness that contains the fuel injectors and such?
2007 Honda CBR125R
2004 Suzuki GS500F
2006 Honda CBR600RR
2000 Honda CBR929RR
2003 Kawasaki ZX-6R
RothmansRR is offline
post #4 of 15 (permalink) Old 09-14-2015, 12:52 PM
RothmansRR's Avatar
https://www.600rr.net/vb/17-03-06-rr-...-cbr600rr.html
Have a read through that, and this:
https://www.600rr.net/vb/17-03-06-rr-...006-600rr.html
2007 Honda CBR125R
2004 Suzuki GS500F
2006 Honda CBR600RR
2000 Honda CBR929RR
2003 Kawasaki ZX-6R
The Following User Says Thank You to RothmansRR For This Useful Post:
RR.Bran (09-14-2015)
post #5 of 15 (permalink) Old 09-14-2015, 06:25 PM
venomenon83's Avatar
Images: 5
Feedback Score: 9 reviews
If you think the've replaced the engine than no one here have the power to tell you whether its an 03-04 or 05-06. The easiest way and only way is to go to DMV and let'em run the engine numbers.
venomenon83 is offline
The Following User Says Thank You to venomenon83 For This Useful Post:
post #6 of 15 (permalink) Old 09-14-2015, 08:25 PM Thread Starter
Originally Posted by RothmansRR View Post
Got it! Thank you. If anyone is looking for their EIN Engine Identification Number, it is : "on the 03-05 the engine serial # is on the rear, bottom of the engine on the left side - on a raised boss."
RR.Bran is offline
post #7 of 15 (permalink) Old 09-14-2015, 08:28 PM Thread Starter
For sure. That was my problem. I didnt know where to find the number. My next question was gonna be where do I go with the number. Ill try the DMV. Thanks
RR.Bran is offline
post #8 of 15 (permalink) Old 09-18-2015, 04:37 AM
ink38's Avatar
As far as the wiring harness it should mount right up to either motor though. Only difference might be a few slightly different connecters
ink38 is offline
post #9 of 15 (permalink) Old 09-18-2015, 11:39 AM Thread Starter
So far my issue has been with the headlight/cluster harness. I bought one for an "03/04" as my frame is a 2003. The male plug off the cluster harness to the cluster was a different size. I remember something else (tip over sensor or running light, i believe) didn't fit or was absent all together. Ive been running with only a temp gauge and speedo. Its a real PITA to check your tank EVERT time I ride. If I forget the bike kindly reminds me by leaving me stranded.. Sucks.. Once I figure this out I can get the right harness.
RR.Bran is offline
post #10 of 15 (permalink) Old 09-23-2015, 12:20 PM
RothmansRR's Avatar
You can just shake the bike (not when riding obviously), then you'll know...
I remember my GS500F used to have a fuel petcock, when the bike would start stuttering I'd just change it to go to reserve. We don't have that on the RR but you can also just keep an eye on your mileage? I do roughly 220km when the reserve light starts flashing, at which point there's 4L remaining, still quite a bit.
So if you know to check every 200km, you shouldn't really be stranded...but I can understand, it's a nuisance.
2007 Honda CBR125R
2004 Suzuki GS500F
2006 Honda CBR600RR
2000 Honda CBR929RR
2003 Kawasaki ZX-6R
post #11 of 15 (permalink) Old 09-23-2015, 12:49 PM
tripage's Avatar
Feedback Score: 91 reviews
Has your ignition been messed with?
If you look under the key you can see if you have the zener diode. If you do not then it's an 05-06. If you do it's an 03-04. From the wiring the 03-04 ECM is different from the 05-06 and would have to be rewired for it to work. Or the ECM would have to be replaced as well
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #12 of 15 (permalink) Old 10-14-2015, 03:01 AM
OveRReV's Avatar
Images: 16
You can tell the difference between the 03-04 & 05-06 600RR engines the code that is cast on the head, it's on the intake side right beside where the thermostat housing is bolted to the head, it's big.
MEE-1G = 03-04
MEE-2G = 05-06
The connectors on the speedometer sensor are different between the 2 but it's just a matter of swapping the sensor.
I'm running an 05-06 engine in my 03 600RR.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #13 of 15 (permalink) Old 10-14-2015, 05:00 AM
OzMoto's Avatar
The fairings on that bike looks like something CycleCruza would ride...
Ride carefully - You are invisible.
FB | YT
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R
Sold: 2001 NSR150SP | 2012 CBR250R
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
post #14 of 15 (permalink) Old 10-14-2015, 08:29 PM
TheFozz08's Avatar
Lol'd.
Shots fired.
2006 CBR600RR - First and current bike
2000 Subaru Outback - First and current cage
1982 CB650SC - Fixed and sold
System: Phanteks Enthoo Primo, 3570k @4.4, 2x7950 CF, 16GB 1600MHz, Maximus V Formula, 2xWD Black 1TB raid0, WD Red 2TB, 840 Evo 240GB, Corsair AX850
Watercooling: Swiftech MCP655 pump, Swiftech Apogee HD CPU, 2xSwiftech Komodo 7950, Stock motherboard block, Custom reservoir, 2xAlphacool UT60 240, Alphacool XT45 360
TheFozz08 is offline
post #15 of 15 (permalink) Old 11-19-2015, 11:23 PM
[QUOTE=RR.Bran;7516066]So far my issue has been with the headlight/cluster harness. I bought one for an "03/04" as my frame is a 2003. The male plug off the cluster harness to the cluster was a different size. I remember something else (tip over sensor or running light, i believe) didn't fit or was absent all together. Ive been running with only a temp gauge and speedo. Its a real PITA to check your tank EVERT time I ride. If I forget the bike kindly reminds me by leaving me stranded.. Sucks.. Once I figure this out I can get the right harness.[/QUOT
I've personally used a 03-04 sub harness on an 05, and an 05 sub harness on an 03. The product code is the same for both part numbers. They should be the same. Make sure the harness you bought is actually for an "03/04 600rr".
LRRS / CCS #811
GA600rrGuy is offline
