Starting motor off frame - 600RR.net
post #1 of 7 (permalink) Old 10-16-2015, 12:21 PM Thread Starter
Dubble_R's Avatar
Feedback Score: 11 reviews
Hey guys I have a cbr1000rr motor I'm looking to test compression on. The motor is off the frame, no harness or anything hooked up.
I was wondering what the process was to get it to turn over so I can get some readings on it.
I've got a battery hooked to the starter and grounded but I believe there needs to be switch in order to get it turning over.
Anyone know?
Dubble_R is offline
post #2 of 7 (permalink) Old 10-16-2015, 12:22 PM
no, you can just put power to the starter.
make sure there's oil in it!
wibbly is offline
post #3 of 7 (permalink) Old 10-16-2015, 01:05 PM Thread Starter
Dubble_R's Avatar
Tried that and nothing happens that's why I figured there much be a switch
Dubble_R is offline
post #4 of 7 (permalink) Old 10-16-2015, 01:19 PM
how did you put power to the starter?
take the positive cable from the starter and hook it up to the battery, then take the negative cable that connects to the engine and touch that to the negative terminal of the battery,
it'll spin. for sure.
wibbly is offline
post #5 of 7 (permalink) Old 10-16-2015, 05:13 PM Thread Starter
Dubble_R's Avatar
There's only a spot for the positive on the starter. So I'm grounding to the motor
Dubble_R is offline
post #6 of 7 (permalink) Old 10-16-2015, 07:12 PM
are you doing it through the starter relay? or direct to the starter.
I can't comprehend how this could not work
wibbly is offline
post #7 of 7 (permalink) Old 10-17-2015, 01:32 PM Thread Starter
Dubble_R's Avatar
Wire from negative on battery grounded to motor, wire from positive on battery directly hooked to starter
Dubble_R is offline
