Engine noise on cold start, any ideas please - 600RR.net
post #1 of 4 (permalink) Old 02-19-2016, 04:31 PM Thread Starter
I have a noise on my 05 600rr has 14000 miles on it, the noise is intermittent and only happens on cold start/neutral for around 30secs to a minute then it's gone. It comes from the rear of the engine near the rear shock and the best way I can describe it is a rotating, slow paced, growling/droning noise. Performance wise it's fine all gears select how they should oil is changed every 2000miles it's very well looked after. And ideas you wonderful lot
Ready90rtr is offline
post #2 of 4 (permalink) Old 02-19-2016, 09:03 PM
VWormer's Avatar
It could be a couple of things. Top end chatter is common due to lack of lubrication during a cold start up. But you said its coming from the rear.. Does the noise increase if you rev the bike??
VWormer is offline
post #3 of 4 (permalink) Old 02-19-2016, 10:12 PM
it's likely normal. the clutch and transmission will make some noise when the oil is cold
wibbly is offline
post #4 of 4 (permalink) Old 02-20-2016, 01:34 PM Thread Starter
I don't apply throttle until it's warm it almost sounds like a pulley going bad in a car of a bearing but the oil was clean when drained a few silver spec but I believe this is normal? And it goes away once the bike gets up to temp
