cbr 600rr engine head abnormality hole - 600RR.net
post #1 of 5 (permalink) Old 06-23-2016, 03:15 AM Thread Starter
I took the head off my 2006 600rr today because the head gasket was leaking coolant in the cyclinder, but noticed that on what I believe is either the coolant passage or oil passage there is a small chunk of aluminium missing or worn away. I thought maybe its electrolysis erosion or cavitation from running straight water in the bike with water weater. Do you think a new head gasket will solve the problem even with that abnormality present on the head? Or do I need to get it welded and machined? Or just a new head?
I would appreciate some solid mechanical knowledge on this please. Thanks :)
kaodixflow is offline
post #2 of 5 (permalink) Old 06-23-2016, 03:33 AM
YG27's Avatar
Wouldn't hurt to get that all cleaned up to stop the corrosion from spreading, wouldn't hurt to get that spot welded and blended in since it's not its just in from the outside to the water passage, and will help with keeping a good seal. I would do a bench check and look for more areas of corrosion. If you find other severe areas might be time to lay it to rest
2A7X3. Aircraft Structural Maintenance.
Any corrosion (Paint, priming, identification, etc) or Fabrication (Sheetmetal, Fiberglass, Tubing, etc)
questions, go ahead and ask and I'll do the best to respond to the best of my knowledge.
Current : '08 CBR1000RR 20160213
Wrecked: '05 CBR600RR 20151221 RIP
Crashes: 2 minor low speed lowsides, 1 50MPH impact.
Injuries: 0 Broken bones, possible tear in shoulder.
YG27 is offline
post #3 of 5 (permalink) Old 06-23-2016, 10:33 AM Thread Starter
Thank you YG27 for your quick feedback. I found some other areas on the head that were starting to corrode after more visual inspection so I think its time to back it in for that head :( Do you know of anyone selling a head on here? Thanks
post #4 of 5 (permalink) Old 06-23-2016, 12:58 PM
Soponcio Virtual's Avatar
My biggest concern in this case would be...
ŅWhere is the missing chunk?
Those can destroy an engine inside out!
Honda CBR600RR 2003 - Gone! (the blond)
Honda CBR600RR 2007 - On the road! (the brunette)
Soponcio Virtual is offline
post #5 of 5 (permalink) Old 07-16-2016, 08:53 AM
OveRReV's Avatar
Images: 16
Either buy a good used head or have the corroded areas welded then resurface the cylinder head for flatness. That can still be fixed.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
