Oil leaking, do you have an idea? Description in thread. - 600RR.net
post #1 of 8 (permalink) Old 09-13-2016, 02:04 PM Thread Starter
Chris Harrison's Avatar
Oil is leaking above right side crank case, not sure what it could be. Any ideas or suggestions?
Chris Harrison is offline
post #2 of 8 (permalink) Old 09-13-2016, 02:21 PM
mran556's Avatar
Pic didnt show up..
2007 Cbr600rr Black
mran556 is offline
post #3 of 8 (permalink) Old 09-15-2016, 11:31 AM
zx1kay's Avatar
I have the same issue. Very small amount that runs down the right side of the case cover.
zx1kay is offline
The Following User Says Thank You to zx1kay For This Useful Post:
dixon cider (09-15-2016)
post #4 of 8 (permalink) Old 09-15-2016, 03:19 PM
Rad Rage's Avatar
For the love of God someone post a pic.
2011 CBR600RR 'X-Ray' Build Thread
https://www.600rr.net/vb/showthread.php?t=294795
Co-President of Team46
"My bike is too fast for the track" Ubercool ZX-14R rider.
Rad Rage is offline
The Following User Says Thank You to Rad Rage For This Useful Post:
post #5 of 8 (permalink) Old 09-15-2016, 07:11 PM
Speak917's Avatar
Could be from the oil pressure switch (has the black rubber boot). I noticed the same on my 03 and it was coming from the pressure switch. Ordered a new pressure switch, o-ring, and sealing bolt and problem was solved.
Speak917
Speak917 is offline
The Following User Says Thank You to Speak917 For This Useful Post:
dixon cider (09-16-2016)
post #6 of 8 (permalink) Old 09-18-2016, 01:27 PM Thread Starter
Not the best picture
post #7 of 8 (permalink) Old 09-18-2016, 01:38 PM
illinifan16's Avatar
I had the same leak... check to make sure your oil sensor bolt is tight. Even if its just slightly loose it will leak.....
illinifan16 is offline
post #8 of 8 (permalink) Old 03-20-2017, 12:41 PM
Amp4027's Avatar
Take the toolbox off and see just where it is coming from. Its just that 10mm bolt you see there next to your finger. Toolbox has a nub that sticks inside a framehole. My guess is its coming from the valve cover gasket, or CCT gasket if someone tinkered with it.
2005 CBR600RR - bone stock
Amp4027 is offline
