CCT help! Head removal - 600RR.net
post #1 of 11 (permalink) Old 11-13-2016, 11:55 PM Thread Starter
mran556's Avatar
Removing my head so i can turn my block into a table lol. I want to keep the head in good working order. Im confused about the cct in the service manual it says I need to turn it clockwise until it stops then insert the key. Isnt that just putting alot of tension on the cam chain? Why would I do that if I'm removing the head and cams? Is it going to damage the head, chain, cams or cam sprockets in anyway? I dont have a key but noticed with a small screw driver i can move the cct clockwise with ease but i cant go counter clockwise with out a good deal of force..
I dont rly have a great understand of the cct or how it would damage something. Whats it going to damage just the chain? Thats goin in the trash anywho.
2007 Cbr600rr Black
mran556 is offline
post #2 of 11 (permalink) Old 11-14-2016, 12:47 AM
turning it clockwise pulls the tension off the chain
or you could just remove it and worry about turning it back in once it's out. it doesn't matter.
wibbly is offline
dixon cider (11-14-2016)
post #3 of 11 (permalink) Old 11-14-2016, 01:37 PM Thread Starter
mran556's Avatar
Ill try that it prolly wont be going back in. So going clockwise retracts the tensioner
2007 Cbr600rr Black
mran556 is offline
The Following User Says Thank You to mran556 For This Useful Post:
post #4 of 11 (permalink) Old 11-14-2016, 01:40 PM
yeah, the tensioner extends. so with standard threads, turning clockwise would pull it back in.
wibbly is offline
The Following 2 Users Say Thank You to wibbly For This Useful Post:
dixon cider (11-14-2016), mran556 (11-14-2016)
post #5 of 11 (permalink) Old 11-14-2016, 07:33 PM
Lifetime Premium
dixon cider's Avatar
I also saw a couple of youtube videos out there. Wibbly explained it better than most of the other information I found show.
First time rider over 40. Finally made it!
dixon cider is offline
post #6 of 11 (permalink) Old 11-14-2016, 10:55 PM Thread Starter
mran556's Avatar
Thanks for the help boys! Took it off i understand now.
You guys think i could get the clutch basket bolt, flywheel bolt, and other one on the crankshaft off with a electric impact?
I think im going to find out. Clutch basket bolt is staked on and im not gunna undo that.
2007 Cbr600rr Black
mran556 is offline
post #7 of 11 (permalink) Old 11-15-2016, 08:16 PM
yeah an electric impact will probably do it. assuming it's a hard hitting 1/2"
you can un-stake the clutch hub nut with a small screwdriver and a mallet.
wibbly is offline
dixon cider (11-15-2016)
post #8 of 11 (permalink) Old 11-15-2016, 09:49 PM Thread Starter
mran556's Avatar
Just need a screw driver and hammer. Left everthing in my lair haha could have thought this threw a little more just brought my sockets home.
2007 Cbr600rr Black
mran556 is offline
post #9 of 11 (permalink) Old 11-16-2016, 12:07 AM Thread Starter
mran556's Avatar
Anyone know is the flywheel interference or tapered?
I think i can just leave it on not sure what im going to do with the crank..
For anyone that wants the know a socket in the flywheel (deepwell 8 or 10mm) between the flywheel and case will hold it so you can get both bolts out flywheel and i think the other is the starter gear bolt
Also haven't tried it yet but a long extension between the basket and the end of the work bench should allow you to get the clutct basket lock nut off
2007 Cbr600rr Black
mran556 is offline
dixon cider (11-16-2016)
post #10 of 11 (permalink) Old 11-16-2016, 12:09 PM
haaha no, ramming an extension into the basket won't let you get that nut off.
the nut is connected to the input shaft, not the basket. you don't need to hold the basket you need to hold the hub. once the hub is off the basket slides over the input shaft on a bearing and meshes with the spline on the crank shaft.
don't be ramming extensions into anything. please
wibbly is offline
post #11 of 11 (permalink) Old 11-16-2016, 01:52 PM Thread Starter
mran556's Avatar
Oh bummer about the basket. Shouldn't hurt anything could use a wooden dowl too
2007 Cbr600rr Black
mran556 is offline
