2004 CBR Very Loud Engine Knock - 600RR.net
post #1 of 7 (permalink) Old 10-01-2017, 01:25 PM Thread Starter
Hi, new to this forum.
Have a 2004 CBR 600 RR and I was riding a couple days ago and the engine started to make a very loud knocking noise, sounds like it's from the right hand side.
I took off the clutch cover and could see nothing wrong and so also took off the head cover and again nothing.
The engine starts fine, revs fine and goes through the gears fine but the knocking noise is unbearable. I replaced the CCT with a manual one and tensioned it correctly to no avail.
Any ideas? I do have video with the sound but struggling to attach it, will only let me attach photos
Jason Riley is offline
post #2 of 7 (permalink) Old 10-01-2017, 01:51 PM
Honda-Power's Avatar
Just upload to youtube and link it.
unfortunately it sounds like you are describing a rod knock
2003 Honda CBR600RR
- Renthal Sprockets (15/45) - DID 520ERV3
- Micron Slip on - Pair/EVAP delete
- SS front brake lines - Gilles Rearsets
Honda-Power is offline
post #3 of 7 (permalink) Old 10-01-2017, 03:01 PM Thread Starter
https://youtu.be/1Pag1M8Cp8c
This is a link to the video
post #4 of 7 (permalink) Old 10-02-2017, 05:31 AM
RothmansRR's Avatar
I am no expert but by your description (and sound in the video) it seems like the main bearings are buggered? I sincerely hope I am wrong.
If it were the main bearings, there's no way you'd be able to see it by removing the clutch cover or the head.
If you're lucky you could get away with replacing just the affected rod/bearing but wouldn't make sense financially or practically because it's best to change all of them at once, and then you'd probably need to polish up the crankshaft in case it's damaged by the shot main bearing. Lots of time involved and possibly money if you need to get it fixed by someone else.
How was the power delivery when riding as it occurred? Please don't go full throttle and test this out in case it is indeed the main bearings
It's probably only slightly worn out, but with higher rpm it will make more noise and get worse. Best to not fire it up until it's confirmed.
2007 Honda CBR125R
2004 Suzuki GS500F
2006 Honda CBR600RR
2000 Honda CBR929RR
2003 Kawasaki ZX-6R
RothmansRR is offline
post #5 of 7 (permalink) Old 10-05-2017, 12:27 PM Thread Starter
This is why I'm slightly confused because I suspected bearings, however the bike runs perfectly as it should and the power deliver is fine just a very loud knock!
When I took the head off some of the bolts on the cam chain cogs were loose, the gaskets around the engine look new and I'm wondering if it's been rebuilt and some of the bolts have not been hardened off properly causing the knock?
post #6 of 7 (permalink) Old 10-06-2017, 01:52 AM
Sounds like a main bearing or a rod bearing. It would not be unusual for the bike to still run decently well with such a condition, however, surely it will not run for long.
2003 Honda CBR600RR
post #7 of 7 (permalink) Old 10-09-2017, 09:14 PM
OveRReV's Avatar
Images: 16
Sounds like rod knock, drain your oil & if you see bits & pieces of metal in the oil your engine is screwed.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
