Bad battery or bad rectifier on CBR600RR - 600RR.net
post #1 of 26 (permalink) Old 10-14-2018, 12:17 PM Thread Starter
Hi all,
having a problem with my 03' CBR600RR bike. Dead battery after driving for a bit. Battery voltage:
not started 12.4v
Idle 11.5v
2000 rpm 12.5v
5000 rpm 12.9v
Just want to be sure if it's the battery or rectifier before I buy new parts. I'm hoping it's not stator!
I replaced the Rectifier about 5 years ago with OEM because it was over charging.
Any thoughts would be appreciated!
Thanks,
Bill
cbr600rrkid is offline
post #2 of 26 (permalink) Old 10-14-2018, 12:50 PM
Test the stator. It's not hard to do. Meter on AC volts, unplug the stator connector and check volts between all 3 lines. Should be 20ish at idle, and over 50 at 5000
You cannot diagnose a problem without testing. There is no way for anyone here to tell you what is wrong based on the information you have provided.
wibbly is offline
The Following 2 Users Say Thank You to wibbly For This Useful Post:
cbr600rrkid (10-14-2018), dixon cider (10-28-2018)
post #3 of 26 (permalink) Old 10-14-2018, 01:20 PM Thread Starter
Ok...I'll check the stator for voltage. Just use the tester leads in each of the 3 lines? Does the negative test lead have to be grounded? Just asking because I don't want to fry the stator!
Thanks,
Bill
post #4 of 26 (permalink) Old 10-14-2018, 01:30 PM
there are 3 wires. call them A B and C. measure A to B, then B to C, then C to A
the stator has no ground reference so there's no point in measuring to it.
you can't fry the stator measuring volts, no matter how you hook up the leads (unless you short it out with one lead somehow), volts measurement is high impedance, it doesn't draw any appreciable current.
wibbly is offline
The Following 3 Users Say Thank You to wibbly For This Useful Post:
cbr600rrkid (10-14-2018), dixon cider (10-28-2018), tary preisser (10-14-2018)
post #5 of 26 (permalink) Old 10-14-2018, 01:48 PM Thread Starter
Thanks! Will try it!!
post #6 of 26 (permalink) Old 10-14-2018, 04:48 PM Thread Starter
Got 20v at idle and 54v at 5000rpm. So that seems ok. Whew!
post #7 of 26 (permalink) Old 10-14-2018, 05:01 PM
on all three readings?
wibbly is offline
post #8 of 26 (permalink) Old 10-14-2018, 05:29 PM Thread Starter
Yes....all three!
I'll look for an easy way to check rectifier. My meter doesn't have diode mode so that may be a challenge! I'm going to take it to a shop to get tested.
Thanks,
Bill
post #9 of 26 (permalink) Old 10-14-2018, 05:47 PM
if the stator is producing voltage then it's the rectifier.
wibbly is offline
post #10 of 26 (permalink) Old 10-14-2018, 05:51 PM Thread Starter
If it is the rectifier what aftermarket would you recommend? This is my 2nd OEM rectifier so I'm NOT getting another OEM. I see one made by DB Electrical....would this be decent?
https://www.amazon.ca/gp/product/B00...K6Y9EEQB&psc=1
Thanks,
Bill
post #11 of 26 (permalink) Old 10-14-2018, 05:52 PM
don't buy motorcycle electronics on amazon.
buy a shindengen mosfet type from roadstercycle
Home
wibbly is offline
cbr600rrkid (10-14-2018), dixon cider (10-28-2018), tary preisser (10-27-2018)
post #12 of 26 (permalink) Old 10-14-2018, 06:32 PM Thread Starter
Home
Thanks Wibbly! Really appreciate your help! Will keep this thread updated!
Bill
post #13 of 26 (permalink) Old 10-27-2018, 03:41 PM Thread Starter
Just a follow up...
replaced battery, added extra battery ground wire and installed new Rick's rectifier. Here's where I'm at.....
not started 12.8v
Idle 11.6-12v when hot (1000rpm)
Idle 13.9v when cold (1300rpm)
2000 rpm 12.5v when hot
5000 rpm 12.9v when hot
Stator puts out 15v AC at idol
Stator puts out 55v AC at 4000rpm
So after all that it still seems my battery is still not charging properly when hot. Any further suggestions would be appreciated.
Thanks,
post #14 of 26 (permalink) Old 10-27-2018, 08:15 PM
Wazoo's Avatar
New or not, it sounds either like your R&R is bad, or wiring coming from the battery to the R&R is bad. Perform the checks shown in these videos and you should be able to isolate the problem.
https://youtu.be/F8EjV0IjW9Q
https://youtu.be/ted0_4On29M
Wazoo is offline
The Following User Says Thank You to Wazoo For This Useful Post:
post #15 of 26 (permalink) Old 10-27-2018, 10:42 PM
C. Chaos's Avatar
Your problem is the stator. Did check it using the diode check function of your meter? Pull your cover off and I bet you have at least one burnt coil. I just went through the same thing on my 07.
C. Chaos is offline
post #16 of 26 (permalink) Old 10-27-2018, 10:46 PM
you can't diode check a coil.
wibbly is offline
post #17 of 26 (permalink) Old 10-28-2018, 12:36 AM Thread Starter
I did do a voltage check and resistance check on stator. Checks ok.
Thanks,
Bill
post #18 of 26 (permalink) Old 10-28-2018, 12:40 AM
Which rectifier did you buy? And did you check volts at the rectifier itself instead of the battery?
wibbly is offline
post #19 of 26 (permalink) Old 10-28-2018, 09:40 AM Thread Starter
I bought a Rick's Hotshot regulator. I wanted something to just plug and play and have good quality. I will check voltage on rectifier asap!
Thanks,
Bill
post #20 of 26 (permalink) Old 10-28-2018, 04:14 PM Thread Starter
Between rectifier harness side plug-in and battery side I'm getting 12.5 V Bike is off.
With bike running at idle 3.5v on positive wire at rectifier output and 7v at 4000rpm . Same specs when I check the other positive wire on rectifier output.
Stator with bike at idle now seems lower at 4v and 50v at 4000rpm
Hope this helps!
Bill
post #21 of 26 (permalink) Old 11-02-2018, 04:37 PM
Bad stator or magneto.
(Piranha) is offline
post #22 of 26 (permalink) Old 11-03-2018, 11:04 AM
C. Chaos's Avatar
Pull your stator cover and visually check the stator. It doesn’t take long and you will know for sure.
C. Chaos is offline
The Following User Says Thank You to C. Chaos For This Useful Post:
dixon cider (11-03-2018)
post #23 of 26 (permalink) Old 11-05-2018, 04:55 PM Thread Starter
So, I replaced stator with a new Rick's unit.... so new battery, new Rick's rectifier and new Rick's stator. The old stator looked fine! Bike charges up 14.5V when cold but when hot the charge drops down to 11.7v at idol and 12.7v at 5000rpm. I'm no further ahead. Ground checks ok and positive wire from battery to rectifier checks ok. I'm out of ideas and money!
Possibly a defective rectifier? It does get hot sitting right next to exhaust manifold.
post #24 of 26 (permalink) Old 11-08-2018, 09:35 PM
Probably Magneto then
post #25 of 26 (permalink) Old 11-09-2018, 03:41 PM Thread Starter
Stator puts out 10-12v per phase when bike is hot at idol. Seems ok.
post #26 of 26 (permalink) Old 11-09-2018, 03:42 PM Thread Starter
When I unbolted r/r and kept it away from exhaust manifold the charge stayed at 13.9v at 2000 rpm while the engine is hot. Now working perfectly! So the r/r was breaking down from the heat being so close to the exhaust manifold. The Rick's r/r stayed barely warm when it was positioned away from the exhaust. Next step is to relocate the r/r. It does mount to where the r/r stay was mounted but it makes contact with the lower fairing. Anyone ever relocate the r/r? Wondering where the best spot would be?
