05 cbr600rr loses power at certain rpm - 600RR.net
post #1 of 3 (permalink) Old 02-16-2019, 03:38 PM Thread Starter
Rjlattuca's Avatar
So hi everyone I have a 05 cbr600rr and when I am under a heavy load or WOT when the bike is accelerating it seems to
Lose power at 9000-10000 rpm then Comes back to life after 10000 rpm..then in between 120000-13000rpm it does the same thing again. Loses power. It only does it between those exact rpms every time. Please help if anyone has ever experienced this befor. Thank you
Rjlattuca is offline
post #2 of 3 (permalink) Old 02-17-2019, 03:44 AM
Ruby Racing's Avatar
These are just suggestions.
Sounds electrical, so check the plug caps are on securely, maybe put new spark plugs in if they haven't been changed in a while, they might be breaking down.
Also might be a sensor problem: air temperature sensors; water temperature sensors.
Possibly a loose wire? Hard to find, but start at the connections on the battery and make sure they are tight. Vibrations at certain revs might be enough to loosen them.
Ruby Racing is offline
post #3 of 3 (permalink) Old 02-17-2019, 07:43 AM Thread Starter
Rjlattuca's Avatar
Thank you for the response. I am gonna put new plugs in it and do a coolant flush at the same time. I was told about this yellow ground block that may have a loose connection as well. Just have to find that and see as well
Similar Threads
Thread Thread Starter Forum Replies Last Post
05 cbr600rr. Loses power at certain rpm Rjlattuca New Members 6 05-16-2019 01:07 AM
2005 cbr600rr loss of power at certain rpm’s Rjlattuca New Members 0 02-16-2019 03:07 PM
Noise at certain RPM yellowneck Troubleshooting 12 05-18-2014 06:24 PM
03 Buzzy/Vibration at certain rpm? 13bRotary Troubleshooting 14 04-12-2012 11:07 PM
Bike loses power after warm... kpxgq Maintenance 12 07-31-2005 04:05 PM
