Primes but won't start - 600RR.net
post #1 of 3 (permalink) Old 02-17-2019, 04:33 AM Thread Starter
Sean Smith's Avatar
Hi I bought my 2003 cbr600rr on Tuesday and had to jump start her as she was sat for 6 months.... Worked fine all day but battery started to drain.... I charged the battery over night and the next morning she fired straight up..... Half hour later she was cranking over strong but won't fire up... I can hear the fuel pump priming and can smell a hint of feul when it's been cranking over.... Would a bad battery still. Let it crank but not fire.... Any help and advice would be awesome
Sean Smith is offline
post #2 of 3 (permalink) Old 02-19-2019, 02:30 PM
I've never known a bike to have a bad battery that lets it crank but not spark.
If you're having to manually charge the battery overnight have you checked the stator output and rectifier? I guess its possible theyre not charging the battery or you're right and the battery is duff.
Can you remove a plug and check it by holding the tip (ground electrode) against the engine block while cranking to see if you're getting spark? If you're not getting spark start with the free/basic checks, loose wires etc. Borrow a battery if needed. May end up trying a new set of spark plugs.
Diefenbaker is offline
The Following User Says Thank You to Diefenbaker For This Useful Post:
tary preisser (02-20-2019)
post #3 of 3 (permalink) Old 02-20-2019, 01:33 AM
07-12 experience only...
Battery needs to be very good condition to get the above bikes working right.
If flat for 6 months, try fresh batt?
tary preisser is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
2004 CBR 600rr fuel pump primes and has spark but will not start Paulmorphy Troubleshooting 1 05-13-2014 09:04 PM
Fuel pump primes still won't turn on. astat4 Troubleshooting 3 08-20-2013 09:53 PM
pump primes, starter cranks but no start stuartmcivor Troubleshooting 5 04-25-2013 11:07 PM
03 primed intermittently, now primes all the time but won't start Kubiks Troubleshooting 3 03-12-2013 03:29 PM
Primes but dosent start DRRSB88 Troubleshooting 2 06-19-2010 07:49 PM
