03/04 Engine into 05/06 - 600RR.net
post #1 of 7 (permalink) Old 02-26-2019, 07:30 AM Thread Starter
Hi all. I'm new to the forum had my CBR for a year and due to some idiocy from myself, I've fried the engine... Let's just say 800ml isn't enough oil.
So I'm on the hunt for a new block, obviously, I'd prefer a 05/06 block as it'll make it plug & play. But I understand that 03/04 will fit but it has the below differences. Can someone fact check this for me?
- Speed sensor will need taken off my 06 block and put on the 03?
- The EFI input to the rail will need modifying to reach the opposite end?
- From my understanding, the 05/06 has an extra oxygen sensor (so says wiki) does this matter?
Anything else worth highlighting?
If that's it then it's an easy job. If I go ahead with an 03/04 then I'll post a DIY step by step on it (promise).
Thanks,
gavL is offline
post #2 of 7 (permalink) Old 02-26-2019, 10:30 AM
InsolentMinx's Avatar
Crap.
Sorry to hear about the engine.
Personally, I'd probably aim to fit an engine from the same year to avoid the extra work, but all the best with the hunt and keep us updated on the project :)
Steve
'04 CBR 600RR
IBA #40198
InsolentMinx is offline
post #3 of 7 (permalink) Old 02-28-2019, 08:01 AM Thread Starter
Bought an 04 block so, going to get a conversion write-up.
gavL is offline
post #4 of 7 (permalink) Old 02-28-2019, 08:22 AM
noice
Steve
'04 CBR 600RR
IBA #40198
post #5 of 7 (permalink) Old 03-01-2019, 02:20 PM
Arjay67's Avatar
The cylinder head on the '06 is superior. I would take the cams and the head from the '06 and put them on the new engine. That way it will be the same thing.
06 CBR 600 RR
Arjay67 is offline
post #6 of 7 (permalink) Old 03-03-2019, 07:25 PM Thread Starter
Thanks for that. After realising just how easy it is to drop the engines out (apart from the rear mount bolts as they've never been off or greased in 13 years) I'll be throwing the 04 in quick once everything is clean and stripping the 06 for spares :)
gavL is offline
post #7 of 7 (permalink) Old 03-03-2019, 09:34 PM
Arjay67's Avatar
Yeah, there's actually a Honda document outlining the differences between the first gen bikes and the second gen. Apparently they changed the cylinder head for more mid-range torque. My guess is the ECU was probably changed to also support the same. Either way, the '06 head, and probably the cams, are the preferred ones to use.
06 CBR 600 RR
Arjay67 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Swapped 06 engine into 03 Model but no ECU Theaviator3000 Engine Tech 1 07-16-2016 08:55 AM
will a 2005 600RR engine fit into an 03? greenmonster 03-06 RR Modifications 7 07-29-2010 11:37 PM
600rr 06 engine direct swap into an 03?? lee jensen 03-06 RR Modifications 2 09-11-2008 03:44 AM
looking into getting into racing RRrider05 Racers 0 10-21-2007 05:09 PM
Wanting to swap 1000RR engine into 600RR - Help evils-03-RR 03-06 RR Modifications 40 08-11-2004 07:50 PM
