Cam Chain Noise after valve adjustment - 600RR.net
post #1 of 7 (permalink) Old 03-28-2019, 09:21 PM Thread Starter
Plusaq's Avatar
Hey guys,
Just finished up doing my valve adjustments on my bike. Once i put everything back together the bike would not start. I diagnosed it as something wrong with my cam chain or my timing ended up out of wack im not sure.
With my bike all assembled again, when i turn the crankshaft i feel a clank or almost a slap of the cam chain when it reaches a certain point in the turn. Does this mean that my timing is off and the bike is no longer TDC? i was quite careful to place the sprockets back exactly on the cam chain where i marked it before taking it apart and the IN & EX line marks horizontal and facing outwards.
Any help would be appreciated.
Plusaq is offline
post #2 of 7 (permalink) Old 03-29-2019, 03:39 PM Thread Starter
Plusaq's Avatar
Just as an update. I tore everything back down to the valves. Took off the CCT and put it back on. Checked the spacing it was all good. Turned the engine over a few times and the slapping noise of the cam chain is no longer present.
I put the bike back together, went to start, did not start again. I tried for a while to start it but nothing happened. I am now totally lost as to what i could have done wrong !!!
Help! :P
Plusaq is offline
post #3 of 7 (permalink) Old 03-29-2019, 06:47 PM
498cm3's Avatar
Do you have all your sensors plugged back in? Injectors and coils plugged back in?
Sent from my XT1031 using Tapatalk
498cm3 is offline
post #4 of 7 (permalink) Old 03-29-2019, 07:14 PM Thread Starter
Plusaq's Avatar
Yup all injectors and coils and in and from what i can see there is no sensor or plug i left out. BTW i reposted in the Troubleshoot section as that is where i should have put this post in the first place.
The engine actually turned over but then stopped it didnt get far. However i tried using starter fluid sprayed in the intake and it helped it start better. I am thinking maybe gas is not reaching the plugs.
Plusaq is offline
post #5 of 7 (permalink) Old 03-29-2019, 07:58 PM Thread Starter
Plusaq's Avatar
Problem solved....Thank you all!
Plusaq is offline
post #6 of 7 (permalink) Old 03-29-2019, 07:59 PM
498cm3's Avatar
What was the problem?
498cm3 is offline
post #7 of 7 (permalink) Old 03-29-2019, 08:11 PM Thread Starter
Plusaq's Avatar
The stupidest thing ever.....my gas hose to the tank was crimped.... By fluke i had the tank angled up and decided hey...let me try it now...fired right up.
im just happy its over and hopefully my **** auto CCT is back in properly.
Plusaq is offline
The Following User Says Thank You to Plusaq For This Useful Post:
498cm3 (03-29-2019)
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cam Chain still tight during Valve Clearance after using cam tensioner locking tool AwakenedRider Troubleshooting 19 06-15-2018 02:14 AM
Idle valve adjustment - post valve replacement trolley Maintenance 9 03-09-2015 08:08 AM
Ticking noise after valve adjustment, chain tensioner? Slickrick592 Troubleshooting 4 11-08-2010 03:05 PM
Cam chaft removal/ valve adjustment jz0888 Maintenance 5 03-13-2009 09:50 AM
Cam chain guard or also known as cam chain cover for a 92 cbr 600. firehawk109 Wanted 9 08-11-2006 10:58 AM
