Car guys: Help me pick a power plant for possible future kit car - 600RR.net
post #1 of 25 (permalink) Old 05-19-2015, 11:40 PM Thread Starter
CK_32's Avatar
Alright so I'm in the market for putting together a kit car in the form of an Ariel Atom. I love everything about the atom but the price tag.
Mainly looking for a track/street fun toy. Found a local shop to bend and roll the tubing.
Now I'm trying to figure out what I want to plant in it and have the shop make motor mounts for.
My original idea was a 04 -05 STI turned into a RW 2WD. Copy but IMO one up the Type R Honda motor in the factory Ariel. But the STI motors are notorious for blowing up as I found out.
Then I started thinking what about a V8 out of a junker 90's camero... More power output, less motor strain.
Note what ever the donor car will be will be donating wheels, brakes steering wires ect ect basically cutting out the body.
Also will be a salvaged donor. To cut costs, since 60% of the donor is being scrapped or parted anyways. I just need the guts.
So technical opinions, what is the better option/power plant for best dependability/power output per $$. Plan to upgrade and tune this down the road but want a decent base to start with for the initial build.
So what and why? Main focus best investment and good track oriented power option.
My YouTube channel.
CK_32 is offline
post #2 of 25 (permalink) Old 05-27-2015, 08:49 PM
FightingChance's Avatar
Feedback Score: 10 reviews
A lot will depend on how much the car less engine weights, and the geometry of how the suspension works. There's a reason some of these small track/kit cars don't have monster motors. A smaller boosted powerplant can make power delivery manageable by a human where a V8 may just sit and roast tires or otherwise make driving aggressive a chore.
Honda K series motors are stout and can be boosted. GM Ecotec 4 cyl with turbo as well. Will it be mid mounted or front mounted?
FightingChance is offline
post #3 of 25 (permalink) Old 05-27-2015, 10:20 PM
G Money's Avatar
http://www.superstreetonline.com/fea...-s600-rat-rod/
Check that article out. Fun little 2 seater that is pretty much built from motorcycle parts. Using two rear suspension units, one for each tire, 1000rr engine, all for under $10k. Not so much a kit car, but I really like what the guy did.
'03 600 RR - ~33,000 miles (14,000 from me)
Yoshimura RS-5 Slip on - Arrow Stainless Headers - BMC Street Filter - PCV - EK 520 Chain on Driven Sprockets - CoreMoto Stainless Lines (F+R) - Dan Kyle PAIR Delete - The2Wheels Shorty Levers - Vortex V3 Rearsets - Woodcraft Frame Sliders & Bar Ends - Woodcraft Stator and Clutch Covers - Cox Radiator Guard - Renthal Dual Compound Grips - 1000RR Kill Switch and Throttle Housing - TST IT and FE - Proton Flushmounts
G Money is offline
post #4 of 25 (permalink) Old 05-27-2015, 10:37 PM
Cornell's Avatar
I had a friend do a similar kart build with a Honda H22 from a Prelude. The transmission is cable actuated for shits which made the build interesting.
Most of us buy salvaged chevy trucks to swap the V8 into a 350Z or 240sx these days. Those parts are a dime a dozen and can easily make good power na.
Cornell is offline
post #5 of 25 (permalink) Old 05-27-2015, 10:39 PM
Maynard
JohnDoubleR's Avatar
Just make a t-rex
2W1R
2012 M1100 EVO
JohnDoubleR is offline
post #6 of 25 (permalink) Old 05-27-2015, 10:42 PM
Cornell's Avatar
Even if you opt for the chevy 5.3 you can throw in a Z06 cam and intake manifold for more than enough power for a tube chassis car. You could still utilize some components like brakes. Bend your own SS lines and make brackets for cheap aftermerket Wilwood calipers
Cornell is offline
post #7 of 25 (permalink) Old 05-28-2015, 05:40 AM
kenoman's Avatar
Pmed you CK
kenoman is offline
post #8 of 25 (permalink) Old 05-28-2015, 06:07 AM
Soponcio Virtual's Avatar
Why not a Lotus Super Seven kit car???
They are superlight and can mount quite some big engines...
Honda CBR600RR 2003 - Gone! (the blond)
Honda CBR600RR 2007 - On the road! (the brunette)
Soponcio Virtual is offline
post #9 of 25 (permalink) Old 05-28-2015, 03:42 PM Thread Starter
CK_32's Avatar
Before the motor, it's looking to sit from 800 to 1,000 lbs. Depending on strength and size tubing I choose.
Yea that was a worry I thought as well was the 8 might be too much power/torque for the light car and just spin.
But the k series on the atom is super charged and tuned to almost copacity.
But that's another issue I came across after mocking it up. How can I turn a FF or FR/AWD into a MR car? The trans linkage would be a issue and might need to be revamped. Which is cool to work around/on it. But could also pose a huge expence/head ache if harder than expected.
My YouTube channel.
CK_32 is offline
post #10 of 25 (permalink) Old 05-28-2015, 04:17 PM
^ that will be your greatest engineering challenge of this project, I think. You're right, I don't think you can just plug a transverse engine and axle from a FWD into an MR chassis and expect it to work okay. A longitudinal motor like the Miata 4 cyl may be a better fit because of the simplicity in which it works. Maybe an entire drivetrain from a Toyota MR2 could be a huge step skip if you can source one.
post #11 of 25 (permalink) Old 05-28-2015, 08:36 PM
03cbr-rider's Avatar
Yeah, never mind that beautiful Lamborghini diablo in the background...
03cbr-rider is offline
post #12 of 25 (permalink) Old 05-28-2015, 08:47 PM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
I would turbo charge a Busa motor.
TheX is offline
post #13 of 25 (permalink) Old 05-29-2015, 01:23 AM
Grab a 3s-gte out of an sw20 mr2.
That whole car would be a good donor.
Skip the Subaru, way too much effort to mid mount. Youll need custom everything and it will just blow up anyway.
wibbly is offline
post #14 of 25 (permalink) Old 05-29-2015, 01:26 AM
Every time I think of buying a used wrx I just imagine how much I would cry when I learned that I had to get into both heads on that damn motor
post #15 of 25 (permalink) Old 05-29-2015, 01:28 AM
Maynard
We have an 08 STi.. It's fun. Lol
2W1R
2012 M1100 EVO
post #16 of 25 (permalink) Old 05-30-2015, 12:36 PM Thread Starter
CK_32's Avatar
Looked into it, power to weight wouldn't be that great. Awesome motor for a sport bike, some what in the low end for a cager.
Would be sufficient enough, but would make the motor work harder than it was meant for. Where a cager motor would be having a vacation pushing this literal tubing around.
My YouTube channel.
CK_32 is offline
post #17 of 25 (permalink) Old 05-30-2015, 12:37 PM Thread Starter
CK_32's Avatar
I thought about i, didn't like the numbers. I'll look again. How good are their trannys? For gear ratio/ruggedness?
Even thought of a porche motor, but like the saburu with its thrown rod propensity, I read the porche trannys usually start to give or need servicing around 50k due to design.not to mention I hate the exhaust note of porche
My YouTube channel.
CK_32 is offline
post #18 of 25 (permalink) Old 05-30-2015, 01:19 PM
The 3s is a very very durable engine. You should be able to find a wrecked JDM sw20 for a nice price.
Another option, but harder to find would be a 4a-ge from an aw11 mr2.
Nice and revvy and bomb proof. Its a beautiful engine, not massively powerful, but you don't need power for this build
wibbly is offline
post #19 of 25 (permalink) Old 05-30-2015, 04:01 PM
TheX's Avatar
Images: 2
500 HP not enough?
TheX is offline
post #20 of 25 (permalink) Old 05-31-2015, 05:13 AM Thread Starter
CK_32's Avatar
Only 93lb of torque.
Your butting an engine made to push a 500 lb machine, push a 1,300 lb machine. It can probably do it well. But stress the engine and parts while doing it.
Where taking a car engine like the boxer or SW20 which is made to push a 3,100 lb car, into a 1,300lb tube chassis. Longevity. HP doesn't mean everything. Also making a set up to house the busa motor would be tasking like trying to fab the AWD STI to MR linkage.
My YouTube channel.
CK_32 is offline
post #21 of 25 (permalink) Old 05-31-2015, 09:17 AM
Maynard
I got one of those. You want it CK? I'll sell it to you for $10k.. I'll give you the car with it as well.
2W1R
2012 M1100 EVO
post #22 of 25 (permalink) Old 05-31-2015, 04:50 PM
mran556's Avatar
What about a caterham kit car or factory five? How much do you want to stick into this? I think the atom would be one of the most expensive options.
2007 Cbr600rr Black
mran556 is offline
post #23 of 25 (permalink) Old 05-31-2015, 05:28 PM
A friend of mine posted this crazy thing on his fb feed today:
https://www.facebook.com/LoveFab?fref=photo
post #24 of 25 (permalink) Old 05-31-2015, 05:53 PM Thread Starter
CK_32's Avatar
Yea the atoms are very expencive. But they also use high end parts. I'm just trying to base my own take of the atom because they have the most streamline design. Everyone else sells box cars.
Haven't seen cat yet, I did give fab a look. I'll check them out again don't remember their selection. Researching more im now thinking FR/FF kit. MR has a handeling issues if you loose rear traction.
My YouTube channel.
CK_32 is offline
post #25 of 25 (permalink) Old 05-31-2015, 05:54 PM Thread Starter
CK_32's Avatar
I'm good, thanks tho lol
My YouTube channel.
CK_32 is offline
