Best way to clear engine of watery gas? - 600RR.net
Maintenance Maintenance advice and questions are here
post #1 of 9 (permalink) Old 08-12-2019, 07:33 PM Thread Starter
Sprite's Avatar
Me and a few buddies were riding the other day. Stopped to fuel up, and as we were leaving, all 4 bikes died in the lot. Found out they had 13 gallons of water in their premium gas tank. We drained our tanks, added heet + new gas. My cbr (fuel injected) will run, but throttle is super unresponsive and laggy. Plus idle is choppy. Any advice for fixing this?
Sprite is offline
post #2 of 9 (permalink) Old 08-12-2019, 10:26 PM
498cm3's Avatar
I don't know if it's the best way, but first thing I would do is rock it out with some SeaFoam in that piece.
Sent from my XT1031 using Tapatalk
498cm3 is offline
post #3 of 9 (permalink) Old 08-13-2019, 02:00 AM
As above SeaFoam and/or specific fuel dryer should work......
Where'd you buy the gas?
Specifics are always welcome on stuff like this!
tary preisser is offline
post #4 of 9 (permalink) Old 08-13-2019, 11:14 AM Thread Starter
Sprite's Avatar
Got at at a Conoco
Sprite is offline
post #5 of 9 (permalink) Old 08-13-2019, 12:54 PM
Tulsa OK @ Conoco = bad gas!
post #6 of 9 (permalink) Old 08-13-2019, 01:18 PM Thread Starter
Sprite's Avatar
In Kellyville OK. Small town gas station owned by some dude overseas I found out apparently
Sprite is offline
post #7 of 9 (permalink) Old 08-13-2019, 03:09 PM
Had some problems in Mexico with this a while ago....
FWIW, My sympathies, I'm careful to not buy gas at dodgy places, if at all possible...you no doubt understand!
That said, these bikes will only go for about 125 miles on a brimmed tank, sometimes you can get into a "got no other choice" zone pretty easily.
PS I've learned OTF not to run gas tank level below 2-3 bars, the pump can o'heat when tank is low......I've always refilled at that level. But this maybe is BS?
post #8 of 9 (permalink) Old 08-13-2019, 08:08 PM
As long as your bike is running just run it until the diluted stuff is out of the system. No need to do anything special.
Even after draining the tank there's still a fair bit of gas in the pump and the lines to the injectors.
Once you can get combustion it's just a matter of time before your system is full of the pure stuff again.
Local mechanic told me to spray brake cleaner into the fuel line when I have them disconnected as this displaces the water and then evaporates.
Bat-1 is offline
post #9 of 9 (permalink) Old 08-15-2019, 04:05 AM
astarsrider87's Avatar
Would avoid sea foam... I would personally flush the system the use some high octane fuel or race fuel and a bottle of octane booster
andrew.
2007 CBR600RR
HIDís
ASV Shorty Levers
Throttle Tube
Steel Braided Brake Lines
K&N Filter
Velocity Stacks
Leo Vince Slip
CAT Eliminator
Power Commander
astarsrider87 is offline
The Following User Says Thank You to astarsrider87 For This Useful Post:
tary preisser (08-15-2019)
