Ques: Turn signal light - 600RR.net
post #1 of 8 (permalink) Old 06-15-2008, 02:07 PM Thread Starter
itz.damenace's Avatar
Feedback Score: 5 reviews
Question Ques: Turn signal light
What would cause a turn signal light to go solid? I hope this makes sense. I'll explain my right turn signal goes solid when activated. My left is fine. I know is cars it can be as simple as a bulb replacement. Is it the same as bikes? I have an 05 btw with clear alternatives and flush mounts, neither work (solid, not blinking) on the right-side from the cluster all the way to the rear.
Thanks in advance!
2005 Black Tribal
Facebook Me
itz.damenace is offline
post #2 of 8 (permalink) Old 06-15-2008, 02:21 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Two options
Get some resistors or change the turn signal relay ( easier , cleaner )
check out this link
http://www.customled.com/PRODUCTS/FL...sher_relay.htm
Moeman is offline
post #3 of 8 (permalink) Old 06-15-2008, 02:30 PM Thread Starter
Thanks Moe!
2005 Black Tribal
Facebook Me
post #4 of 8 (permalink) Old 06-16-2008, 11:41 AM
Knightslugger
Posts: n/a
It worked before?
check your wiring.
post #5 of 8 (permalink) Old 07-01-2008, 05:37 PM Thread Starter
Originally Posted by Knightslugger View Post
It worked before?
check your wiring.
Yes it worked perfectly...I was riding to work, glanced down and noticed it.
2005 Black Tribal
Facebook Me
post #6 of 8 (permalink) Old 07-01-2008, 05:48 PM
Knightslugger
Posts: n/a
then i'd check the wiring. all of it. after that you MAY wish to isolate the Turn Signal relay, or replace it altogether. i'd take a volt meter to the relay to see if it's sending pulse voltage. it could very well be that the (unserviceable) relay in the dash is broken.
post #7 of 8 (permalink) Old 07-01-2008, 05:54 PM Thread Starter
I'll check it..thanks! I may just replace the relay all together.
2005 Black Tribal
Facebook Me
post #8 of 8 (permalink) Old 07-23-2008, 10:15 AM Thread Starter
I've ordered the relay as Moe suggested haven't had time to install it. However my right turn signal started working again, crazy. In order to make it work I have to activate the left first then right works like a champ. I'll replace the relay.
But my question is, is it something else I need to look at?
2005 Black Tribal
Facebook Me
