clutch problems, or not ? - 600RR.net
post #1 of 23 (permalink) Old 06-23-2008, 12:09 PM Thread Starter
Question clutch problems, or not ?
i am new to sportbike maintance and so on, i have on the other hand worked on all my mx bikes, so i am not a compleate dumbass. FYI
my bike feels slow- it does not pull hard when i am hard on the gas and does not "wheelie" as easy as it should. i am in second gear goin 20 mph, i will pull in the clutch and rev to 7 grand and let the clutch go hard and the front wheel stays on the ground. does this sound right ?
the only change would be me adding a honda brand fully synthetic oil the the motor.
Chiefkickabitch is offline
post #2 of 23 (permalink) Old 06-23-2008, 12:28 PM
sethr21785's Avatar
Images: 2
Feedback Score: 14 reviews
sounds normal to me.. maybe you should try a -1 +2 gear conversion...
Originally Posted by Knightslugger View Post
who fuking cares, really guys. get the sand out of the vagges.
sethr21785 is offline
post #3 of 23 (permalink) Old 06-23-2008, 01:18 PM
Knightslugger
Posts: n/a
sounds like a technique issue, not technical. perhaps you should post up in the stunter's section.
post #4 of 23 (permalink) Old 06-23-2008, 02:33 PM Thread Starter
what RPMS are yal running, say 6th gear 80 mph
post #5 of 23 (permalink) Old 06-23-2008, 02:37 PM
Feedback Score: 7 reviews
as long as you didnt get the hp4m then you are fine.
try this 2nd gear high rpms
lean over the tank to keep the front end down
roll off quickly then roll back on.
if your clutch is slipping the rpms will skyrocket but you wont go anywhere.
(cover the clutch and rear brake just in case)
RShackleford is offline
post #6 of 23 (permalink) Old 06-23-2008, 02:39 PM
Knightslugger
Posts: n/a
i've never really paid attention to tell you the truth. it is what it is. i'd take a guess at say 7000 or so.
post #7 of 23 (permalink) Old 06-23-2008, 02:40 PM Thread Starter
is that the full synth ?
post #8 of 23 (permalink) Old 06-23-2008, 02:53 PM
Knightslugger
Posts: n/a
well there's HP4 and HP4M. HP4M has moly in it and can cause clutch slippage, HP4 does not.
and it's more of a semi-synthetic. HP4S is the full synthetic (which doesn't mean it's 100% synthetic).
post #9 of 23 (permalink) Old 06-23-2008, 03:01 PM Thread Starter
i think something is up then b/c im runnin 9 to 10 k or so.
post #10 of 23 (permalink) Old 06-23-2008, 03:05 PM
Knightslugger
Posts: n/a
Has the final drive been re-geared? have you adjusted your speedometer to read accurately? you'd know if the clutch is slipping. your engine would rev like nutz and you wouldn't go anywhere.
post #11 of 23 (permalink) Old 06-23-2008, 03:13 PM Thread Starter
im not shur on the gears. but i just think the clutch is slipping, just not extream like you described. i belive it can happen over time and not all at once.
post #12 of 23 (permalink) Old 06-23-2008, 03:22 PM
Knightslugger
Posts: n/a
but it will. if it's slipping, it's usually not by little bits. in a fast, and high, revving engine like the CBR600 it'll be immediate.
post #13 of 23 (permalink) Old 06-23-2008, 03:28 PM Thread Starter
ok thanks, so for now i should be fine ? or is there something i can do or check?
post #14 of 23 (permalink) Old 06-23-2008, 03:40 PM
Knightslugger
Posts: n/a
you can check your sprockets... stock is 16/43
Old 06-23-2008, 03:48 PM
RShackleford
This message has been deleted by RShackleford.
post #15 of 23 (permalink) Old 06-23-2008, 03:50 PM
do the check i told you about, if your clutch is going, it will slip like crazy
post #16 of 23 (permalink) Old 06-23-2008, 03:51 PM Thread Starter
alright thanks, i willlet ya know something tomarrow
post #17 of 23 (permalink) Old 06-24-2008, 09:47 AM
Simple way to tell if your clutch is slipping is when you are hard under acceleration, is your RPM's going way up without your acceleration changing? If not your clutch is probably ok. Burning clutches also have a very distinct odor, do you notice that?
okiedokie is offline
post #18 of 23 (permalink) Old 06-24-2008, 12:06 PM Thread Starter
i think the rpms are moving up real quick with not as much forward movement. i guess i always thought a 600 would scare me a little, but the bike seems so manageable. if i were to get a new clutch, any suggestions?
post #19 of 23 (permalink) Old 06-24-2008, 12:15 PM
Knightslugger
Posts: n/a
it's not the straight line speed that'll scare you, it's how fast it can take a corner that scares the **** out of me (sometimes).
it's not a TL1000.
I think it's ridiculously powerful for it's size. i don't know what you're comparing this bike to but you saying it doesn't FEEL that powerful... doesn't really mean much to us.
post #20 of 23 (permalink) Old 06-24-2008, 01:56 PM Thread Starter
a clutch seems pretty cheap way to see if that would give me any power though. and i did buy it used with 15k miles.
post #21 of 23 (permalink) Old 06-24-2008, 02:31 PM
Knightslugger
Posts: n/a
if that's how you feel about potentially spending money you could do without it, then go for it. people have different priorities.
post #22 of 23 (permalink) Old 06-24-2008, 05:35 PM Thread Starter
i know, riding is up there on my priorities.
post #23 of 23 (permalink) Old 06-24-2008, 06:04 PM
clutches arent bad.
clutch pack is like 100ish if you install yourself
