Oil Leak - 600RR.net
post #1 of 4 (permalink) Old 06-29-2008, 10:56 AM Thread Starter
jmosesso's Avatar
Oil Leak
Should the plastic oil fill cap have a washer on it?
My bike has been leaking some around the cap which eventually ends up on my tire... Maybe it's just that i have a little too much oil and should drain some.
jmosesso is offline
post #2 of 4 (permalink) Old 06-29-2008, 12:37 PM
NewRedRider's Avatar
Images: 24
Yes there should be an O-ring under the filler cap.
Crank the bike and let it warm. Shut the bike off and hold it level with tires on level ground. Look through site glass and check oil level. If you're between the high and low marks then your oil level is fine.
NewRedRider is offline
post #3 of 4 (permalink) Old 07-01-2008, 11:20 PM Thread Starter
jmosesso's Avatar
i got some plain ole rubber o rings from advance auto, will these be fine? i put it on today and it stopped the leak, i'm just wondering if they will hold up or if i need anything special.
jmosesso is offline
post #4 of 4 (permalink) Old 07-03-2008, 09:35 PM
As long as it is close enough to the same size and makes that seal it should be fine. From what I remember the OEM one is rather thick. So if you used a thin one it may crap out when things get hot or over time. Anyway, the part number is 91307-KF0-003 and it is around $1.50 at your local dealer. It's a 18x3 O-Ring.
"People take different roads seeking fulfillment and happiness. Just because they're not on your road doesn't mean they've gotten lost."
"The proper gear can make the last guy finish first!"
"I didn't lose my mind, I sold it on Ebay."
James06CBR is offline
