Knocking sound and temps after Willow Springs - 600RR.net
post #1 of 13 (permalink) Old 07-09-2008, 12:29 AM Thread Starter
I had to cut my trackday short when I started hearing a knocking/fluttering sound coming from my engine and once i pulled off the track the temp was at 244.. Someone told me that I could've blown a valve, which I doubt.
So a couple days later (today), I start it up, and I still hear the fluttering sound whenever I give it throttle. Its not very loud, but definitely noticeable especially above 4k. Also, my temps seem to be climbing much faster, but I didnt let it get above 223 tonight. Any ideas on what this could be? Could it be a buster water pump or is it something much worse? Any tips greatly appreciated before I start tearing into the bike..
Motocicletta is offline
post #2 of 13 (permalink) Old 07-09-2008, 01:13 AM
'03 Double_R's Avatar
Images: 2
Can you post a vid so we can hear exactly what it sounds like?
'03 600RR red/black #728.
Armour Bodies race bodywork
Leo Vince CF slip on
520 conv. D.I.D VX2- Drive Systems superlite 15/45
Bridgestone S20's
Vortex rearsets
Vortex clip ons
ASV gold shorties
GPR damper
Ohlins 46PRXLS triple clicker
K Tech .95 fork springs
Maxima 15wt fork oil
Woodcraft sliders
Tech Spec tank pads
Galfer SS lines
'03 Double_R is offline
post #3 of 13 (permalink) Old 07-12-2008, 09:44 PM Thread Starter
sorry no camera.. ill try to record it with my phone maybe or laptop. I think I may take it to a shop sometime this week and let them check it out
post #4 of 13 (permalink) Old 07-12-2008, 09:56 PM
Krash's Avatar
whatever it is, it doesnt sound good. keep us posted, would like to know what happened
Krash is offline
post #5 of 13 (permalink) Old 07-14-2008, 10:52 PM Thread Starter
Took the clutch cover off today to check for anything out of place or loose but couldnt find it. Also, I found out that as the longer I ride and the hotter it gets, the noise gets more obvious. Also, after a certain amount of time riding, it really doesn't want to cool down - i.e. the temps just start climbing leading to overheat. The fan kicks on, but doesn't really do much.
Would a faulty CCT do this? Could it be a busted water pump? Any advice appreciated before I take it to the stealer. Oh and the bike only has 4500 miles on it with 2 trackdays.
post #6 of 13 (permalink) Old 07-15-2008, 08:28 PM
Krash's Avatar
water pump does come to mind. cct wouldnt cause these issues
Krash is offline
post #7 of 13 (permalink) Old 07-21-2008, 09:57 PM Thread Starter
It doesn't seem to come from the water pump side though. Oh well, I did something I promised myself I would never do and took it to the $90/hr stealer. F**k it. They're gonna diagnose it first so hopefully after that I can take over. I'll keep you guys updated for future reference.
post #8 of 13 (permalink) Old 07-24-2008, 03:35 PM Thread Starter
little update
Okay, this is weird. I just called the dealer and basically it came down to changing my oil or going in to replace rods or something else (20-22hrs at $90/hr - HA!) I'll do an oil change, but I dont see how the oil deteriorated after 2 track days and a few hundred miles or regular riding. It was the good Repsol race oil as well.. Synthetic oil shouldn't just go bad so quickly - or can it?
If it was really the rods - would those be RPM-dependent? The noise from my bike IS RPM-dependent and the warmer the bike, the worse the noise. Ill keep you posted. I may possibly need to buy an engine from one of you here soon!
post #9 of 13 (permalink) Old 07-28-2008, 11:29 AM
Dr. GoFast's Avatar
maybe your thermostat isn't opening ? (you need a new t-stat). rods? what kind of rods? i highly doubt your synthetic oil took a dump so fast, although the high temps could've killed it much faster so it is a possibility and if I was you, i'd certainly change it. it is not the ROOT of the problem though, just an after-effect. were you running water wetter? 50/50 or what?
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #10 of 13 (permalink) Old 07-28-2008, 12:55 PM
Dr. GoFast's Avatar
how many miles on the bike? cam chain could've skipped a tooth and thrown the timing off, making the spark plugs overheat and fail, injectors/coils could be faulty causing overheating, many things could be wrong. is it throwing a code?
2004 Honda CBR600RR
-Woodcraft rearsets
-Woodcraft Clip-Ons
-Elka 3-Way Shock
-CRG gold levers
-PCIII
-green painted rims
-Tanktredz
post #11 of 13 (permalink) Old 07-30-2008, 03:34 PM Thread Starter
I havent gotten around to the bike yet as I've had a million other things to do and work, but it only has 4500 miles, i ran regular 50/50 coolant in it.
If it skipped a tooth - would that lead to permanent damage? I am guessing that could be related to the CCT as well.
Like I mentioned before though - at idle there is no noise. Not until about 3k rpms. Ill be posting updates once I dig into it again. Thanks for all the replies and help so far
post #12 of 13 (permalink) Old 07-30-2008, 04:15 PM
Try this - take the fairings off (if not off already) open the cap on the radiator and blip the throttle - if fluid doesn't come (just about) flying out I'd be betting the water pump gave up the ghost.
twilkinson3 is offline
post #13 of 13 (permalink) Old 09-18-2008, 03:23 PM Thread Starter
Well, my engine is toast. Basically I've got valve leakage and scoring on the piston (s). So yeah people change your old coolant to prevent overheating! I learned it the hard way... Now I've got to find a new motor before Laguna in Nov.
