Engine does not rev up 12000rpm! - 600RR.net
post #1 of 15 (permalink) Old 07-16-2008, 02:14 PM Thread Starter
I have a problem with my 03 600rr. The engine does not go up the 12000rpm.
I believe it is a fuel pump problem because I had something similar before and when I changed the fuel pump everything went normal again.
600rr03 with Gianelli slip on.
The bike has 85000 kms and the previous problem showed up at 55000. Why again?
Please help
spas is offline
post #2 of 15 (permalink) Old 07-16-2008, 02:40 PM
Knightslugger
Posts: n/a
was the replacement pump used or new?
post #3 of 15 (permalink) Old 07-16-2008, 04:15 PM Thread Starter
It was brand new, the bike has never left of fuel, when it reaches the last black tile I refuel immediately. I don't know what happened again!!!
spas is offline
post #4 of 15 (permalink) Old 07-16-2008, 04:16 PM
Knightslugger
Posts: n/a
Are you using clean fueling station? one with regular business?
post #5 of 15 (permalink) Old 07-16-2008, 04:24 PM Thread Starter
Yes I use 2 stations that have more than regular bussiness I would say!
The only point is that they are not Shell or Bp or something like this.
spas is offline
post #6 of 15 (permalink) Old 07-16-2008, 04:26 PM
Knightslugger
Posts: n/a
bah, big deal... If it gets regular business, chances are it's good gasoline.
check your tank for irregularities, such as rust or paint chipping. also, check to make sure you haven't pinched any fuel lines under the tank.
post #7 of 15 (permalink) Old 07-16-2008, 04:49 PM Thread Starter
ok i'll do it tomorrow and tell you the results.
By the way, I don't think I have such problems because I didn't take off the fuel tank for about 6 months now...
Thanks a lot
spas is offline
post #8 of 15 (permalink) Old 07-16-2008, 04:51 PM Thread Starter
also I have to say that I use unleaded fuel of 95 octanes
spas is offline
post #9 of 15 (permalink) Old 07-16-2008, 04:51 PM
Knightslugger
Posts: n/a
at that point, i agree. probably not a pinched line. as unlucky as it may be, maybe you've gotten a string of bad pumps!
95 RON right? Not PON or MON.
post #10 of 15 (permalink) Old 07-16-2008, 05:27 PM Thread Starter
ron. Is it better to use higher? I saw the sticker on the fuel tank of the 07 model saying: use only premium unleded fuel!
spas is offline
post #11 of 15 (permalink) Old 07-16-2008, 07:39 PM
have you checked / replaced your inline fuel filter?
Diving Pete is offline
post #12 of 15 (permalink) Old 07-16-2008, 08:31 PM
Knightslugger
Posts: n/a
inline fuel filter? Where's that at? the only fuel filter i know of is built into the fuel pump...
post #13 of 15 (permalink) Old 07-16-2008, 08:33 PM
Knightslugger
Posts: n/a
95 RON is fine. Premium does not mean the different grades of fuel available at the pump (Regular, Super, Premium whatever) but rather the quality of the fuel. basically means don't use crap fuel. 87 PON (85 MON or 91 RON) is fine.
post #14 of 15 (permalink) Old 07-16-2008, 08:38 PM
kphybrid's Avatar
lol...KS u know way to much about these bikes..lol...inline fuel filter..guess that was a page from the cagers manual...another page from the cagers manual...some vehicles(cars) when they have an issue(no rev) its because the ECU is in safe mode...something went wrong and sent a code which then makes the car rev a certain amount till the code is cleared or the battery terminal is removed and then attached...do bikes have this also?..my friends car had a bad O2 sensor and would only rev half the rev range...this is a question and not an answer or recommendation since i am not as knowledgeable as KS...i'm thinking no since i never heard of this "safe mode" on bikes before...
kphybrid is offline
post #15 of 15 (permalink) Old 07-16-2008, 08:54 PM
Knightslugger
Posts: n/a
some do some dont. the 2007+ has a limp mode that has become popular knowledge with those who have either replaced their exhaust system and eliminated the servo in the exhaust system.
i am unsure if the 2003-2006 has such feature, but it has yet to be pronounced. rev limits is usually either caused by malfunctioning showerhead injector activation or a weak fuel pump.
