possible tranny problems - 600RR.net
post #1 of 5 (permalink) Old 07-19-2008, 07:08 PM Thread Starter
So the other day after changing sprockets I went to put my shift linkage back on. I tapped the part that goes on the shifter shaft back on lightly when I realized that the shifter seemed to be stuck between gears. I got the shifter hooked up and moved it up and down attempting to go through the gears and there was no feel or actual shifting going on. This is when I realized the shaft itself had been pushed into the housing. I pulled it back out (towards me) and it made a good solid clunk. I thought that it could be just some fluke that I have never really noticed.
Well started the bike back up and the tranny was making a clunking noise. It really kinda sounds like a dry clutch on a Ducati except quieter. It makes less noise with the clutch in and changes sounds when the bike is moved side to side. I think I have knocked a circlip into the bottom of the tranny, but I'm just reallllllly hoping its something stupid.
Just wanted to get your guys input.
Nofive-0 is offline
post #2 of 5 (permalink) Old 07-21-2008, 12:28 PM
Did the shift rod slide thru the engine casing toward the right hand side of the bike? if it did I'd bet the retaining spring on the shifter star came loose - you'll need to take the right side engine case cover off and inspect he clutch - on an 03-06 the shift star is in the upper left corener of the cavity behind the clutch outer basket - if it's loose you're looking at taking out the clutch basket (pita) to get at it - hope this helps
twilkinson3 is offline
post #3 of 5 (permalink) Old 07-22-2008, 12:10 AM
shiftn3rdon1's Avatar
cbr with a tranny problem? nonsence
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #4 of 5 (permalink) Old 07-22-2008, 11:12 AM
Knightslugger
Posts: n/a
not so nonsense when you consider what happened.
post #5 of 5 (permalink) Old 07-22-2008, 11:20 AM
CTM_Patron's Avatar
same thing happened to my friend on his 06. he tapped the linkage back on with a hammer and ext...lol
we ended up having to take off the right cover, and entire clutch basket to get to this metal tab that had gotten pushed out/bent.
check if this works. it's part #1 on the "gear shift-drum"
http://www.bikebandit.com/houseofmot...r-2006/o/m2058
1: PLATE
,A AC 211773-001 Enter 0-99 $3.51
CTM_Patron is offline
