I need help guys...please... - 600RR.net
post #1 of 8 (permalink) Old 07-24-2008, 04:40 PM Thread Starter
hey guys sorry for all the WTF... but i really need help. I changed my spark plugs and put in a new K&N air filter on my 06 cbr600rr and now my oil light and FI light stay on??? the oil light blinks 2 time every 3 secounds and the FI light just stays on...WTF man. i made sure i pluged back all the wires when i was done. What do you think i did wrong and what should i do.
Thank for your help.
black350z600rr is offline
post #2 of 8 (permalink) Old 07-24-2008, 05:20 PM
Knightslugger
Posts: n/a
2 blinks means MAP sensor problem on Gen1 and 2 CBR600RRs. might be different on Gen 3, i donno off hand. i don't have my reference here. 's at home.
2 1/2 second blinks is a code 2 (above)
1 1.3 second blink followed by a 1/2 second blink is a code 11 (Speed sensor issue).
post #3 of 8 (permalink) Old 07-25-2008, 10:58 AM
Knightslugger
Posts: n/a
i could have sworn i responded to this before.
2 blinks .5 seconds apart is a code 2 (MAP Sensor performance issue)
2 blinks 1.3 seconds apart is a code 11 (Speedometer circuit issue)
son of a bitch, i did!
https://www.600rr.net/vb/showthread.php?t=110383
come on guy, don't piss me off... double posting your complaint is not going to get you any more right answers...
post #4 of 8 (permalink) Old 07-25-2008, 11:08 AM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
KS
Lets put a new policy in check *** Ask your question once you will get that answer and the answers for the rest of the questions that follow ***
***Ask the question twice and post multiple threads you wont get no answers at all ***
Moeman is offline
post #5 of 8 (permalink) Old 07-27-2008, 02:22 PM
macko300exc's Avatar
1. check for loose/ poor connections at map (wires)
2. check for proper connection of vaccum hose (check for rubbed hose, cracks)
3.with key on, kill switch on; ceck for 2.7-3.1 volts at ECM connection B12(+) B26(-); incorrect voltage check wiring, if wiring is good replace MAP
i bet your vaccum hose is off, or just a bad sensor if the hose is on the map sensor correctly, trace it to where it connects to the motor. hope that helps
macko300exc is offline
post #6 of 8 (permalink) Old 08-15-2008, 09:51 PM
fall down 7times get up 8
redridinghood11's Avatar
Feedback Score: 30 reviews
hey knightslugger,
can't get to your linked comment above says needs an administrator
race/ride support 2004 & beyond
"fall down seven times, get up eight"
" can't stop stupid sir, i can only slow it down....."
redridinghood11 is offline
post #7 of 8 (permalink) Old 08-15-2008, 09:54 PM
Back in the Day
Moeman's Avatar
Images: 665
Originally Posted by redridinghood11 View Post
hey knightslugger,
The two threads got merged
Moeman is offline
post #8 of 8 (permalink) Old 08-16-2008, 02:04 AM
thanx moe
one more suggestion or possibility as just revealed.........
the map sensor switch isn't mounted firmly & the bracket holding some of the wires along the fuel rail can be poorly mounted. this bracket can also bounce on the map sensor switch causing on/off problems as the switch searches due to being bounced bye bracket/wiring/whatever. once i got this corrected; bike is again running strong
