Fan fuse keep on blowing.. (Problem solved ) - 600RR.net
post #1 of 6 (permalink) Old 07-24-2008, 06:11 PM Thread Starter
Images: 4
Smile Fan fuse keep on blowing.. (Problem solved )
well i have a 04 600rr...
Recently my fan fuse keep on blowing, replace it.. go for a ride... blown... don't know why..
and also my signals don't work now... don't even show me i am blinking on the speedo..
and today super strange... it worked all of a sudden but after i turn off the bike and turn it back on.. it doesn't work...
and what are you guys regular running temp or max with fan on... i went up to 115C today... normal? flush my rad and oil recently so...
thanks in advance for the help..
twoforfree is offline
post #2 of 6 (permalink) Old 07-24-2008, 10:44 PM
KylerR's Avatar
Feedback Score: 7 reviews
are you sure your fan was on when you reached that temp? that is really high.
I'm not sure if i understand it completely and maybe someone can correct me but could it be your voltage regulator? i remember my friend having a similar problem on his old fzr
Bring a spare clutch lever and drive it through his heart. It's the only way to kill a bike thief."-ZachRR
KylerR is offline
post #3 of 6 (permalink) Old 07-25-2008, 03:21 AM Thread Starter
Images: 4
no the fan wasn't go... when its on.. usually under 110C...
this is annoying.. keep replacing the fuse and blow... i have a fan switch too..
post #4 of 6 (permalink) Old 07-25-2008, 10:42 AM
Knightslugger
Posts: n/a
check your wires for signs of deterioration or bare wires. It could be an internal circuit problem in the fan motor. for your signals, check your wires and check your switch.
110C is not normal at all, let alone 115. normal is 80-90C.
post #5 of 6 (permalink) Old 07-25-2008, 05:13 PM Thread Starter
Images: 4
problem solved..
fan was spinning was offset and had some drag so everytime it powers up.. couldn't produce enough power and blow the fuse...
post #6 of 6 (permalink) Old 07-25-2008, 05:13 PM Thread Starter
Images: 4
so replaced fan.. thanks for the help..
Closed Thread
