Need help with Thottle cables ASAP! - 600RR.net
post #1 of 14 (permalink) Old 07-27-2008, 12:01 AM Thread Starter
maine's Avatar
Exclamation Need help with Thottle cables ASAP!
I was changing my right clip-on and I decided to take the lazy route and not change the throttle cables with the new clip-on( it came with the throttle cables and everything else). I took the off of my old clip-on while it was still attached to the forks and slipped it on to the new bar. It seems to go fine but not the throttle is sticking a little. It doesnt snap back closed like its supposed to. Could I have damaged the cables by pulling on them? Is there a way to fix this problem or should I just go ahead and switch out the entire thing and change the cables???
maine is offline
post #2 of 14 (permalink) Old 07-27-2008, 12:06 AM
Dr. GoFast's Avatar
this is really hard to conceptualize without pictures. are you sure you put the two cables in the right place? i'm thinking that if it came with new cables then there's probably something to that...... but then again, i can see how you wanted to be lazy cuz those are hard to get to (you must remove the airbox, throttle bodies, etc....) and a cable's just a cable after-all. if i were you i'd verify that you have the right cable going to the right place (since there are two) and that whatever spring is involved is working properly and that nothing is rubbing or restricting the throttle's movement.
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #3 of 14 (permalink) Old 07-27-2008, 12:07 AM Thread Starter
maine's Avatar
instant bump! I'm trying to finish this tonight.
maine is offline
post #4 of 14 (permalink) Old 07-27-2008, 12:07 AM Thread Starter
maine's Avatar
Give me two minutes and I'll have some pics for you...
maine is offline
post #5 of 14 (permalink) Old 07-27-2008, 12:24 AM Thread Starter
maine's Avatar
Ok, lets see if I can explain this better...
The throttle and the cables in the pic cam off the new bar. So basically I just romoved the bar and put my controls on it. After I did the trottle sticks... So did I mess something up?
maine is offline
post #6 of 14 (permalink) Old 07-27-2008, 12:35 AM
kphybrid's Avatar
if ur bar doesnt have glue residue then it shouldnt stick..check to make sure that ur cables move freely when not attached...ie..move the cable in and out with ur hand..if they feel fine then they arent kinked...u may have the cables wrong like stated above..i had a sticky throttle then realized i had some glue on my bar
kphybrid is offline
post #7 of 14 (permalink) Old 07-27-2008, 12:39 AM
kphybrid's Avatar
just so u know..if im correct then with the throttle tube with 2 holes up..the top cable goes to the hole close to the the lever..the bottom cable goes around the throttle tube and connects to the hole closest to the seat
kphybrid is offline
post #8 of 14 (permalink) Old 07-27-2008, 12:58 AM Thread Starter
maine's Avatar
I didnt mess with the cables on the bike at all so they cant be kinked or anything. Im gonna go check the bar for glue.
maine is offline
post #9 of 14 (permalink) Old 07-27-2008, 01:01 AM
kphybrid's Avatar
make sure inside the throttle tube is clean..i had some glue get inside from sliding on a new grip..the bar itself might not have anything on it..if u didnt mess with the cables then im pretty sure that it is glue...like i said make sure u have the right cable in the right place...
kphybrid is offline
post #10 of 14 (permalink) Old 07-27-2008, 01:07 AM Thread Starter
maine's Avatar
Yea i think that was it... I sprayed a little WD40 on the bar and its working better now
maine is offline
post #11 of 14 (permalink) Old 07-27-2008, 01:08 AM
BOTM 06/2008
Strychnos's Avatar
Try to free some pre-slack and see if that helps. I usually remove all my throttle slack, cause I don't like it. However if I take of too much, I noticed the throttle wouldn't roll back to closed by it self so easily.
Strychnos is offline
post #12 of 14 (permalink) Old 07-27-2008, 01:10 AM
Dr. GoFast's Avatar
the manual specifies 2-4 mm of freeplay in the throttle FYI...basically nothing, but something. i've got mine right at 2mm..... i hate having a lot of freeplay in the throttle as well, seems utterly pointless and is very annoying. when i twist my wrist, i want that thing to GO!
2004 Honda CBR600RR
-Woodcraft rearsets
-Woodcraft Clip-Ons
-Elka 3-Way Shock
-CRG gold levers
-PCIII
-green painted rims
-Tanktredz
post #13 of 14 (permalink) Old 07-27-2008, 01:13 AM
kphybrid's Avatar
glad u got is squared away..this site really does help...quick and accurate response..kinda the opposite of the dealers...they would have sold u a new throttle tube, cable, grip, and clip-on..then charged $80 an hour to put it on with 3 hr labor charge..
kphybrid is offline
post #14 of 14 (permalink) Old 07-27-2008, 01:30 AM Thread Starter
maine's Avatar
^^^ I agree with you 100% which is why they are called stealerships.
maine is offline
