idle adjustment? please help my bike keeps stalling! - 600RR.net
post #1 of 5 (permalink) Old 07-28-2008, 11:20 PM Thread Starter
Question idle adjustment? please help my bike keeps stalling!
whats the deal with the screw at the bottom of the idle adjustment knob? when i turn the knob nothing happens? i wanted to turn the screw and nothing happened as well? and someone said something about if you turn the knob too much it will come out of place from where its connected under the tank? please help me with this problem or if you know why my bike ran fine yesterday and stalled on me today? i tried everything but the only thing i can really think of is my idle adjuster because nothing happens when i turn it? also this might help the bike will start/run but i have to give it gas when i let off the throttle it stalls????
2006hurricane is offline
post #2 of 5 (permalink) Old 08-03-2008, 12:34 AM
bad06rr's Avatar
There is an air "pump" under the air box/tank area that likes to stick open when people mess with the idle adjustment knob and cause this problem. The bike will run fine but die at idle right? Check into that pump. If you need help finding it let me know and I can circle it on the microfiche for you.
Originally Posted by sincalirider View Post
Myspace
facebook: pm I'll add you
bad06rr is offline
post #3 of 5 (permalink) Old 08-03-2008, 12:49 AM
Dr. GoFast's Avatar
the "pump" he's describing is the fast idle wax unit....... you need to turn the idle screw HARD for it to turn, it's not an easy-to-turn screw. i would try the screw before messing with the fast idle wax unit. turn it forward (left) to lower the idle and backward to raise it (right). so, you'll be turning it right.
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #4 of 5 (permalink) Old 08-03-2008, 10:13 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
4 SKU: 16044-MCJ-751
WAX ASSY. (Honda Code 7002207) $37.73
Moeman is offline
post #5 of 5 (permalink) Old 08-03-2008, 10:24 PM
I'm not sure if you are aware of this but on my 03 RR you have to let it warm up before you adjust the idle.
squidlicious is offline
