Bike wont start! PLEASE HELP - 600RR.net
post #1 of 9 (permalink) Old 07-29-2008, 02:08 PM Thread Starter
red_rider24's Avatar
Heres the story. I have never had a mechanical problem with the bike with 9k miles on it now. I took my first long trip on it a little over a week ago, about 750 miles to deals gap and back. The bike set in the garage for the next couple of days. Then when I go to start it, it just cranks and cranks but never fires.
What should I check first in this situation? The plugs or connections? I dont know...
red_rider24 is offline
post #2 of 9 (permalink) Old 07-29-2008, 03:45 PM Thread Starter
Suggestions??? Anyone have a similar problem that can help? Thanks
post #3 of 9 (permalink) Old 07-29-2008, 04:32 PM
Knightslugger
Posts: n/a
First of all, what's the year of your bike? secondly, do you hear your fuel pump prime when you turn the key on and flip the engine run switch to RUN?
Why are details necessary? well, it helps me run through the electrical of the bike in quick order and eliminates a lot of possible leads. for instance, the engine run switch on the 2007-2008 operates differently than the 2003-2006 in that even if switched off the bike will crank but fail to run.
post #4 of 9 (permalink) Old 07-29-2008, 06:38 PM
NattyBoh's Avatar
there is a diagnostic port under the seat. i cant remember where it is at exactly but like knight said, need more info
NattyBoh is offline
post #5 of 9 (permalink) Old 07-29-2008, 09:00 PM Thread Starter
The bike is a 03 and the fuel pump primes when I turn the bike on. Nothing seems out of the ordinary besides the fact that it just wont start.
I talked to a guy who owns a gsxr and he said he had a problem like this and it was a sensor that had vibrated loose or something. He says it happens to a lot of sportbikes and explained to me how to fix it but I dont see what hes talking about. I guess this could be the problem because I've had a lot of bolts mysteriously go missing that I can only figure is from vibration.
post #6 of 9 (permalink) Old 07-29-2008, 09:26 PM
Knightslugger
Posts: n/a
and at this point, neither do i.
try this. charge your battery, then hold the throttle 100% wide open. do this until the battery dies. charge it back up, and try to start it normally. see if she goes.
post #7 of 9 (permalink) Old 07-29-2008, 09:30 PM Thread Starter
Thanks knightslugger I'll give a shot. I have held the throttle open all the way and cranked it for a while. It attempted to fire once by doing this.
post #8 of 9 (permalink) Old 07-29-2008, 09:32 PM Thread Starter
Oh and I forgot to mention that the low fuel light was on when I rolled in the last time. It sitting for a while low on gas shouldnt have anything to do with it should it?
Also if it is a sensor that maybe came loose does anyone know the locations of them so I could check? Thanks
post #9 of 9 (permalink) Old 07-29-2008, 09:37 PM
Knightslugger
Posts: n/a
CKP or CMP sensors are the only two i can think of that would also cause this sort of surface issue.
