Battery issues? - 600RR.net
post #1 of 12 (permalink) Old 07-29-2008, 11:36 PM Thread Starter
Triballurker's Avatar
Battery issues?
Well i have a 05 600rr. I havent been riding the bike much at all...when i first got it i rode it everyday and everything was fine.
Fast forward a bit and i let the bike sit for prolly a month or so and found the battery was dead. So i threw the battery tender on it and it charged in about an hour..started up fine, so i took it for a ride and all was fine.
Again the bike sat for a few more weeks and the battery is now dead. I charged it withthe tender again and now its not holding anything..It started the first time fine and after that dead again. Im thinking its a bad battery....along the right lines?
**Throughout the time it was off the road i started it from time to time to move the oil and such..dunno if that killed it or not..
**05 Black Tribal 600RR
>Yoshimura stainless slip - on
>Scotts dampener
>Black Pazzo shorties w/gold adjusters
>Blue 3rd eye
>Sportech mirror screen
>CA inegrated tail
>OEM solo cowl
>Carbon fiber look/tribal seats
>Stripped wheel lips
>Sylvania silverstar ultras
Triballurker is offline
post #2 of 12 (permalink) Old 07-30-2008, 12:05 AM Thread Starter
Ok so i just did some checking..with a voltmeter on the battery with nothing on it held at 12.59volts.
Went to start it and it dropped down to 6 volts while i was pushing the starter button, tried a second and it dropped to 3.5volts.
My guess the battery is toast
>Scotts dampener
>Blue 3rd eye
>CA inegrated tail
>OEM solo cowl
>Stripped wheel lips
post #3 of 12 (permalink) Old 07-30-2008, 12:54 PM
eeeeeee
Sounds like a garbage battery. Hondas are notorious for EATING batteries left and right, take the battery to the manufacturer and ask them to replace it. I believe most have a 4 yr warranty
YOGATOGAMAN is offline
post #4 of 12 (permalink) Old 07-30-2008, 07:48 PM
Yup. Sounds like the battery is done.
rdog is offline
post #5 of 12 (permalink) Old 07-30-2008, 08:53 PM Thread Starter
yup i replaced the battery and it works like new..now curious what are the voltages i should be seeing at 5000 rpm?
>Scotts dampener
>Blue 3rd eye
>CA inegrated tail
>OEM solo cowl
>Stripped wheel lips
post #6 of 12 (permalink) Old 07-30-2008, 10:38 PM
Knightslugger
Posts: n/a
BINGO! That battery's got OCS and it's done. needs replacement.
Stunt much?
post #7 of 12 (permalink) Old 07-30-2008, 10:40 PM
Knightslugger
Posts: n/a
at 5000 RPM with the high beam on, should be around 13.5 or more. less than 15.5 is the standard. but you';ve got to get a reading from Off and idle first.
post #8 of 12 (permalink) Old 07-31-2008, 12:33 AM Thread Starter
No i dont stunt..maybe the previous owner did..
I checked it off it was 12.4v..on with highbeam at idle 12.9v and over 5000 rpm 13.4v
So it looks liek my charging circut seems fine and it was a bung battery..all fixed now..thanks.
>Scotts dampener
>Blue 3rd eye
>CA inegrated tail
>OEM solo cowl
>Stripped wheel lips
post #9 of 12 (permalink) Old 07-31-2008, 01:40 AM
Hi just out of curiousity what should the battery be at for each stage?
- Bike totally off
- Bike at idle
- Bike on with 5000rpm & high beam on
Want to make sure my battery is indeed o.k
Dee-Mak is offline
post #10 of 12 (permalink) Old 07-31-2008, 04:54 PM
Knightslugger
Posts: n/a
- Bike totally off
- Bike at idle
well, just sitting, the battery should be above 12.6, but that's a relatively low charge state. ideally, 13.2 or so. what's important is that when you start the bike, you immediately see a voltage increase, and the same while testing it at 5000 RPMs.
post #11 of 12 (permalink) Old 07-31-2008, 09:18 PM
Hey Knightslugger, here are what my redings showed. The dealership said it ws fine, but wanted to double check with you guys.
Static - 12.62
Bike off, lights on - 12.30
Bike on at idol - 13.12
Bike at 5k rpm with high beams - 13.95
Dee-Mak is offline
post #12 of 12 (permalink) Old 07-31-2008, 09:20 PM
Knightslugger
Posts: n/a
bike off, lights on = not part of the test.
otherwise, looks good to me.
