Bike died...need help - 600RR.net
post #1 of 7 (permalink) Old 08-08-2008, 08:20 PM Thread Starter
So i rode to school this morning and when I got back to my apt I was idiling in the parking lot when the bike just shut off. Its not getting fuel, when I turn the key to on i cant hear the fuel pump prime. then when i press the start button it just turns over and never cranks. I checked the fuses, nothing blown. I donk know how to check the fuel pump relay. Anyways what do you think is the problem? its a 07 600rr with only 5k miles.
Thoma015 is offline
post #2 of 7 (permalink) Old 08-08-2008, 09:45 PM
CiBeR's Avatar
You got gas in the tank right? Just making sure. My bike did this once and finally I flipped the kill switch off and on and it started right up???
CiBeR is offline
post #3 of 7 (permalink) Old 08-08-2008, 10:13 PM Thread Starter
haha yea theres a full tank, i flipped the kill switch and still it will turn over but not start. I tried disconnecting the battery for a few minutes then.......nothing
Thoma015 is offline
post #4 of 7 (permalink) Old 08-08-2008, 10:48 PM
Dr. GoFast's Avatar
warranty? if so, use it.
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #5 of 7 (permalink) Old 08-09-2008, 01:28 AM
AFwestPunk's Avatar
sounds like the starter relay is fuckard
OG PostwhoreScooter riding HK chasin' SOB
AFwestPunk is offline
post #6 of 7 (permalink) Old 08-09-2008, 05:52 AM
Fuel Pump prime
If you can't hear the fuel pump kick on then it's most likely the relay, there could be a problem with your fuel pump or your bank angle sensor but start with your relays first, test it with one of the other relays to see if you can get the fuel pump to prime.
emev0l is offline
post #7 of 7 (permalink) Old 08-09-2008, 11:44 AM Thread Starter
Well I took out the relay and used a different one and it didnt work......this is a pain....im just going to take it to the shop.
Thoma015 is offline
